Author Topic: stupid bolts on the water pump  (Read 6465 times)
kowalski
  • El\' Duder
« Reply #15 on: April 04, 2006, 04:07:02 AM »
alright so i put a new one in ($50!!!) pretty freakin expensive unit, it was imported from germany:) so now it temp went a bit higher, but (with the fans off) i cannot for the life of me get it to rise above the 1/4 mark!!!!!! what the hell is going on?
Sale:
Fore Sale Thread
« Reply #16 on: April 04, 2006, 09:06:25 PM »
Are you putting it in facing the right way, o-ring & everything?  It should just set right in place, with the spring inside the cylinder head.  If it is staying that cold (which mine used to when the t-stat dies & stayed open), it is either the t-stat, or there is somewhere else that a LOT of coolant is bypassing the t-stat.  Is the housing damaged inside at all?  There should be a little groove between the inlet & outlet side of the housing, make sure it is cleared of gunk.  Also check inside the head where the t-stat site to make sure that there is not some sort of damage allowing the coolant to flow by the t-stat.
kowalski
  • El\' Duder
« Reply #17 on: April 04, 2006, 09:23:53 PM »
there is no damage anywhere, and the passage your talkinga bout, thats on the fitting right? that things is clear as well. i tried 2 different T-stats. the spring is facing inside the head, i tried flipping it... but that reverses the problem as it totaly blocks coolant flow... this is the second brand new stat i'v tried... and im pretty sure coolant couldn't get through anywhere else...? its not burning coolant either as it maintains proper level... so im lost.
Sale:
Fore Sale Thread
