Author Topic: stupid bolts on the water pump  (Read 6463 times)
kowalski
  • El\' Duder
« on: March 20, 2006, 09:11:36 PM »
so my water pump went on the club drive the other day. i was still able to do about half the 5 hour drive, and i had a water pump waiting for me when i got home. so i set to work today to pull it out, got all but 3 bolts out, then i look and see an allen key and i think "thats strange..." so i wip out a 6mm allen key and pop it in there. it has a little flex and then shears off with the end stuck in the bolt. i can't pull it out of the nut, and i can't get the nut out. i need my car tomorrow afternoon, and im not really sure what to do now... anyone got any bright ideas for me?
edit: i forgot to mention it was a craftsmen prof. key, and i'v tried drilling it with a small bit and it just snapped like a tooth pick. i tried low and high rpm's before it broke, and it only made a small pin prick in the key.
Sale:
Fore Sale Thread
kowalski
  • El\' Duder
« Reply #1 on: March 20, 2006, 10:20:16 PM »
well after some consideration im going to weld a piece of metal onto it and pull it out. heat it up and see if i can't get it to come out. ill let you guys know how i fare.
Sale:
Fore Sale Thread
kowalski
  • El\' Duder
« Reply #2 on: March 21, 2006, 12:45:04 AM »
yay! so i figured what the hell its still warm out, i can get enough light with a flashlight. so i got her welded up and got the bolt out. a few light taps strategicly lossend the pump and its out now.
Sale:
Fore Sale Thread
2002maniac
« Reply #3 on: March 21, 2006, 01:42:40 AM »
Congratulations!  You talked yourself through the whole thing ;)
m42technic
« Reply #4 on: March 21, 2006, 02:33:14 AM »
Consider yourself lucky that your waterpump job didnt end up as badly as mine.
Moral of the story, change your coolant regularly kids.  The previous owner of my car didnt.
e9nine
« Reply #5 on: March 21, 2006, 06:27:50 AM »
I was fortunate enough to not have any issues with the water pump R&Rs when I had to perform them. I was thankful as I replaced mine in the parking lot at night with a flash light last winter. NO FUN at all.
kowalski
  • El\' Duder
« Reply #6 on: March 21, 2006, 01:31:29 PM »
Quote from: 2002maniac
hahaha i know... i used some heat, and slight tapping of the hammer in all directions and it loosened it up. it was stuck in there pretty good at the start... but it came out whole. the previous mechanic didn't use anti sieze on the bolts... moral of the story? do it yourself.
Sale:
Fore Sale Thread
kowalski
  • El\' Duder
« Reply #7 on: March 21, 2006, 07:30:49 PM »
alright so new problem. i did all this work because the temp wasn't rising above the 1/4 mark. so i replaced the water pump and T-stat. now i took it out and beat the shit out of it for about 30 min and it only made it a hair above the blue mark. am i just needing to make more power so it runs hotter :) or what should i do?
Sale:
Fore Sale Thread
m42technic
« Reply #8 on: March 21, 2006, 08:07:37 PM »
Are you sure the temp guage is functioning correctly? (ie. grounding nut on insturment cluster)
kowalski
  • El\' Duder
« Reply #9 on: March 21, 2006, 08:41:36 PM »
Quote from: m42technic
yeah it works fine. its steady, works properly. my fan didn't even get a chance to kick in on the medium seetting which should have been about 1/4 way up on the temp guage. (it has its own temperature unit)
Sale:
Fore Sale Thread
m42technic
« Reply #10 on: March 21, 2006, 08:48:14 PM »
Faulty t-stat perhaps.
kowalski
  • El\' Duder
« Reply #11 on: March 22, 2006, 01:52:26 AM »
yeah... i just bought it yesterday, i think im gona take it back and try a new one.
Sale:
Fore Sale Thread
m42technic
« Reply #12 on: March 22, 2006, 03:54:10 PM »
Quote from: kowalski
Let us know how the new one works out.  :)
« Reply #13 on: March 22, 2006, 06:05:22 PM »
Yeah, has to be T-Stat.  You are using the 88C one, right?  That is the 'proper' one.
kowalski
  • El\' Duder
« Reply #14 on: March 22, 2006, 08:26:19 PM »
Quote from: bmwman91
well it had an 88c one, but they gave me a 79.5 C one, which puzzled me, but thats what showed up when he looked up the car.
Sale:
Fore Sale Thread
