according to the internet the ratio of the rear springs is .65
100lbs work as 65lbs and so on,
500front and 292lbs doesn´t sound right,
What are you basing the numbers on?
Also if the sleeve is more then 51mm it will fit, I had a 51mm sleeve opened up by 1mm the other day to make things fit
