coil-over
Author Topic: coil-over  (Read 8299 times)
romkasponka
coil-over
« on: November 28, 2006, 08:10:07 AM »
what do you think? F500/R450 lbs/in
« Last Edit: November 28, 2006, 08:25:11 AM by romkasponka »
E30 318is M42
E36 318is M44
Gunni
coil-over
« Reply #1 on: November 28, 2006, 09:10:44 AM »
according to the internet the ratio of the rear springs is .65
100lbs work as 65lbs and so on,
500front and 292lbs doesn´t sound right,
What are you basing the numbers on?
Also if the sleeve is more then 51mm it will fit, I had a 51mm sleeve opened up by 1mm the other day to make things fit
romkasponka
coil-over
« Reply #2 on: November 28, 2006, 09:14:03 AM »
The rear will be direct fit on the damper. So the ratio will be ~1,1 or more.
suspensio frequency wiil be F 163 cpm, R 186 cpm.
E30 318is M42
E36 318is M44
Gunni
coil-over
« Reply #3 on: November 28, 2006, 09:25:14 AM »
Well in that case,
I belive I read on the gustave site or elsewhere that the rear needs a little more stiffness then the front to neutralize understeer tendency
romkasponka
coil-over
« Reply #4 on: November 28, 2006, 09:31:34 AM »
In my case efective stiffnes is    F500/R540
E30 318is M42
E36 318is M44
coil-over
« Reply #5 on: November 28, 2006, 02:36:55 PM »
What about the upper shock mounting area. You're gonna need beef! 500+ pounds/inch into that? Get out the welder!
romkasponka
coil-over
« Reply #6 on: November 28, 2006, 03:30:59 PM »
I'm thinking about rear strut bar.........
« Last Edit: November 28, 2006, 03:56:13 PM by romkasponka »
E30 318is M42
E36 318is M44
romkasponka
coil-over
« Reply #7 on: November 28, 2006, 03:34:28 PM »
Quote from: D. Clay;14597
What do you mean by saying beef? Sorry for my poor english.
I found that M3 had 685/1027.  :D
« Last Edit: November 28, 2006, 03:37:44 PM by romkasponka »
E30 318is M42
E36 318is M44
Gunni
coil-over
« Reply #8 on: November 28, 2006, 03:34:41 PM »
Quote from: romkasponka;14571
Could you explain why you get that effective ratio?
romkasponka
coil-over
« Reply #9 on: November 28, 2006, 03:37:08 PM »
rear shock is mounted behaind halfshaft, so the shock lever is bigger than wheel lever.
E30 318is M42
E36 318is M44
Gunni
coil-over
« Reply #10 on: November 28, 2006, 03:40:57 PM »
could you explain the painting a little bit more?
where exactly are you thinking about mounting the rear shock?
romkasponka
coil-over
« Reply #11 on: November 28, 2006, 03:54:10 PM »
E30 318is M42
E36 318is M44
Gunni
coil-over
« Reply #12 on: November 28, 2006, 06:59:10 PM »
If you use a strut brace in the back you will probably need to add strenght from it to the body with welding,
Where's the beef?
« Reply #13 on: November 28, 2006, 09:12:42 PM »
Quote from: romkasponka;14605
As in the expression "beef it up". Meaning to reinforce, brace, and  strengthen. It may be a US expression. All of the rear suspension load will be entering the structure at the upper shock mount. It was designed for the shock only and not the shock and spring load.
Here's a link to a picture and text explaining some of the ratios discussed above:
http://e30m3performance.com/tech_articles/susp-tech/eff_rate/eff_rate2.htm
This is the best article I am aware of. Note on the first page the author indicates that his earlier determination was in error. Suspension is art, craft,  science, and voodoo.
romkasponka
coil-over
« Reply #14 on: November 29, 2006, 07:35:17 AM »
Quote from: D. Clay;14642
Yes, I know this article.
I would like to be a woodoo master :)
E30 318is M42
E36 318is M44
