Author Topic: cheap short shifter  (Read 2376 times)
romkasponka
cheap short shifter
« on: November 21, 2006, 05:05:23 PM »
E30 318is M42
E36 318is M44
cheap short shifter
« Reply #1 on: November 22, 2006, 01:18:42 AM »
What material is the shifter made of? Will a MIG welder setup for sheet steel  up to .125" (3-4mm) do the job?
romkasponka
cheap short shifter
« Reply #2 on: November 22, 2006, 04:49:46 AM »
Quote from: D. Clay;14270
It is made of stock shifter material :) and piece of bolt.your welder setup will be fine, but do not overheet the power part of shifter, because you can burn the insert.
E30 318is M42
E36 318is M44
