Author Topic: Upgrade E36 diff to medium case  (Read 2198 times)
Bill K
« on: June 04, 2012, 06:07:40 PM »
I need to update the diff in my DA-powered E36 M42 to a medium case unit as I have just broken a tooth on the CW/Pinion of the original small case LSD. I know the medium case will bolt in and the tailshaft and half-shafts will no longer fit but would appreciate advice on the parts needed.
« Reply #1 on: June 04, 2012, 06:40:10 PM »
Why not use an E30 medium case diff from a 325?
Also towing to the driveline section......
« Last Edit: June 04, 2012, 06:46:44 PM by bmwman91 »
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #2 on: June 05, 2012, 11:23:53 AM »
I believe the E36 differentials have different mounting. Its not as simple as a cover swap like it is between the older models.
-Nick
91 E30 M42 with VEMS
romkasponka
« Reply #3 on: June 05, 2012, 12:56:04 PM »
As I know drive-shaft will fit, but for shure you will have to replace half-shafts. I am running this setup. My friend did this conversion for me and he told me that you can remove something from drive-shaft to shorten it a little.
E30 318is M42
E36 318is M44
