Author Topic: DIY engine tools  (Read 3273 times)
ToniBmwPortugal
DIY engine tools
« on: April 20, 2012, 07:55:03 PM »
Hi there to all!
I've been reading and reading on this forum and i got to a point that i've decided to make/rebuild my own engine.
But this lead me to a problem: what tools are necessary...
So i started this thread to we discuss about the tools: specialized (BMW) or not that are required to work on our cars, especialy the engine. The idea is to make a list with the tool and the function to what is required.
P.S. I'm sorry for the bad english (i,m a Portuguese guy)
List with tools:
-flywheel lock (pin part # 83-30-0-490-861)
-camshaft holding tool
« Last Edit: April 21, 2012, 06:15:41 AM by ToniBmwPortugal »
DanOKC
DIY engine tools
« Reply #1 on: April 21, 2012, 02:08:13 AM »
flywheel lock pin part # 83-30-0-490-861,
and camshaft holding tool.
ToniBmwPortugal
DIY engine tools
« Reply #2 on: April 21, 2012, 06:14:23 AM »
Quote from: DanOKC;112030
ok that's a start :)
d.hitchcock
DIY engine tools
« Reply #3 on: April 21, 2012, 10:44:28 AM »
Thin or flat 32-mm open-end wrench for removing the fan clutch.
A hub holder to aid in removing the fan clutch.
Peake inspection light reset tool.
SHAZAM, GOMER, LOOK AHEAD!
DIY engine tools
« Reply #4 on: April 21, 2012, 12:50:08 PM »
You'll need a long torx socket for the head bolts too, from what I've heard.
DIY engine tools
« Reply #5 on: April 21, 2012, 06:33:03 PM »
Pipe fittings can be machined (sort of requires a lathe) to install rear subframe & trailing arm bushings.
The crank bolt is super easy to loosen...you just need a 4"x4" block of wood and a breaker bar. You then use the starter motor to smack the bar into the wood block until it comes loose.
Tightening that bolt requires some sort of locking tool. I made one out of some 1/2" thick steel plate and a drill press (bolts to the 6 accessory pulley holes, rests against same wood block on driver's side that was used to break it loose).
wazzu70
  • Nasty Nick
  • -Receive: 18
DIY engine tools
« Reply #6 on: April 21, 2012, 06:41:20 PM »
Quote from: DesktopDave;112039
Yes, you need a long thin torx head socket to remove the head bolts with the cams in place.
Technically you are supposed to have a tool to loosen the cam bearing caps. You can also remove the caps without the tool by Loosening/tightening the nuts in a star pattern from the center 1/4 turn at a time. Takes a while, but if you go too fast the hollow cam can snap!
-Nick
91 E30 M42 with VEMS
deansweet
  • -Receive: 12
DIY engine tools
« Reply #7 on: April 22, 2012, 12:24:39 PM »
bmw p/n for head torx bit tool is 83-30-0-490-856-BOE
It's a bit pricey, there's an OEM version one you can pick up at autozone.com for $30?
