Author Topic: Changing oil filter housing gasket - question  (Read 3271 times)
H8Rain
« on: February 13, 2012, 09:22:59 PM »
Do I need to drain the oil from the car to do this? I think not but want to confirm.
Thanks
mr.vang
« Reply #1 on: February 14, 2012, 12:24:00 AM »
i drained mine when i did mine, btw replace the o-ring while your in there.
fs: air bag model knee panel, bmw tools, ects
« Reply #2 on: February 14, 2012, 07:16:40 AM »
Do you mean the o-ring that seals the top of the filter basket?  You don't have to drain the oil to change that o-ring.  It's a bit messy, just be sure to top the car off later on.
If you mean the o-ring that seals the housing to the block...I'd definitely do that after draining the oil.
H8Rain
« Reply #3 on: February 14, 2012, 08:48:43 AM »
I'll be pulling the entire oil filter housing off.  Replacing the Gasket, O-Ring and the Oil Pressure Switch.
Does the oil really sit up that high that it needs to be drained?
Thanks!
mr.vang
« Reply #4 on: February 14, 2012, 11:07:22 AM »
yes, housing to block o-ring.
deansweet
  • -Receive: 12
« Reply #5 on: February 14, 2012, 11:11:42 AM »
You could probably do this without draining the oil but it would probably be less messy if you did change the gasket/o-ring out during a normal oil change. But if you chose to try without draining, check the oil level after completion.
as mentioned in another thread about the housing.
O-ring 24mmx3mm (15/16ths x 1/8th)
H8Rain
« Reply #6 on: February 15, 2012, 08:41:35 AM »
Great.  One more question,  anyone know the torque value for the housing to block bolts?
deansweet
  • -Receive: 12
« Reply #7 on: February 15, 2012, 05:10:22 PM »
Torque specs are 7.1 FtLbs/89 InLbs on the housing.
I just tightened the alt plate and bracket to what I thought was sufficient? I couldn't find specifics on them.
