Author Topic: My FX-R Projector Retrofit Thread  (Read 33110 times)
« Reply #30 on: July 24, 2012, 06:01:33 PM »
LOL!! I just got around to reading your reply. I have yet to test the "spaciousness" of the interior but I'm gonna try your tactic lure them in by teaching them hahaha. I've been single for over a year now I really gotta get back in the sack!
3urotrash
« Reply #31 on: July 31, 2012, 02:31:29 PM »
Quote from: dude8383;113922
haha our rides have a way of keepin our attention on them and not our game lol. hang in there. im in the same boat, just waitin for the right one to come along.
« Reply #32 on: November 25, 2012, 10:51:19 PM »
OK, time for an update! I lost ~7 months thanks to having the original engine blow and me deciding to get a fully built Metric Mechanic 2.1L M42, and getting married + honeymoon, etc. Busy year!
I have dragged my ass for so long on this that there is even a new version of the FX-R projectors out now. I have version 1.1 units presently, and now there is a version 3.0 with an improved lens and beam pattern. So I ordered some 3.0 projectors and will see if they can still fit. They are slightly smaller overall, so I don't see an issue there.
I mocked-up an adapter plate from foam core board to try to get things to fit. The FX-R 3.0 projectors are a little too complicated (geometrically) for me to bother trying to make an accurate model of them with calipers. It was easier just to go arts-and-crafts style instead. Not too bad!
The thickness of the foam core board is a little more than what I will need, so the actual bracket will hold the projector a little closer.
Here is the adapter bracket mock-up.
I went through a number of iterations. Getting the right positioning of the 4 mounting holes was a real pain. They are not symmetric about the projector center in one direction, at least as far as I can tell. That took me a few iterations to figure out!
The projector adapter plate I will make is going to look like this.
Making the bracket is a little complicated since I am doing it all on a manual mill (Bridgeport Series I). I want to apply the lessons I learned while making the first prototype bracket many months ago to get a really clean result. It requires me to machine some additional fixturing to get things done accurately on the rotary table. The fixture will let me clamp the work piece from the outside, and later from the inside once I knock the center portion out and need to cut out the perimeter. The transparent disc seen in the CAD model is the work piece blank.
I got the fixturing plate done this weekend, and surfaced/honed the work pieces to the desired 0.689" (17.5mm). The surfacing was done on a lathe, and I used a 1000 grit water stone hone to knock off the burrs and get things flat.
Here's a closer shot of the fixture. The 3 "extra" holes are there because these discs were picked up at a local aluminum remnant/scrap center. $3.50/lb for 6061 is a lot better than what I would pay if I had the local supply house cut me pieces from raw stock. I got lucky and the scrap place had exactly what I needed!
I should be starting on the brackets themselves in the next week or two.
« Last Edit: November 25, 2012, 11:39:06 PM by bmwman91 »
///m42 sport
« Reply #33 on: December 03, 2012, 09:48:27 PM »
looks pretty legit
« Reply #34 on: December 05, 2012, 04:27:21 PM »
Man am I happy I popped into this thread... Amazing work dude.
« Reply #35 on: December 05, 2012, 05:14:47 PM »
So I am about 60% done machining one of the two adapter brackets. I spent ~3 hours on Sunday evening working on it. Although it does not affect functionality in ANY way, I did make one "oops" lol. Somehow I added things incorrectly in my head and set the radius of a semi-circular cut 0.100" too far out lol. No biggie though (thankfully)! I have some pictures at home that I'll post when I am back from my business trip to Austin. I am hoping to get the first one finished up this weekend so I can trial-fit it and see if any design changes need to be made.
bme30
« Reply #36 on: December 05, 2012, 06:34:03 PM »
You gotta love SW
Great work!
« Reply #37 on: December 10, 2012, 11:22:12 AM »
Quote from: bmwman91;118190
Sounds good! I'll be checking back more often since I know you're actively working on this... I can't even begin to tell you how happy I am to see a retrofit being made.
I linked to your thread over on r3v... Would rather support a fellow member that genuinely cares about these cars!
future RS
« Reply #38 on: December 10, 2012, 11:31:06 AM »
I have been waiting for a reason to change out my sealed beams. I look forward to the completion of this project!
And like previously stated. Good work!
« Reply #39 on: January 29, 2013, 01:20:53 PM »
How is it coming along buddy?
Re: My FX-R Projector Retrofit Thread
« Reply #40 on: July 08, 2013, 12:25:47 AM »
Well, the car is running again. So that is good. My wife and I bought a house, so we have some light renovation to do before moving in. Then the garage will be emptied of furniture and it'll be my proper man cave. I picked up a Craftsman 309 piece tool set, Craftsman click type torque wrenches and various sockets/wrenches that the set didn't include, so soon enough I'll have a place of my own for car silliness. I am open to recommendations for a good low-profile floor jack that won't break the bank either.
I am itching to get back on this headlight project. Anyone work in a machine shop that could hook me up with some discounted CNC action for the adapter plates?
jrobie79
« Reply #41 on: July 16, 2013, 09:50:18 AM »
I've read good things about the harbor freight low profile jacks...the tire shop down the street me has like 10 of them too. Try posting the CNC request over on r3vlimited.com thread, much more traffic
« Reply #42 on: July 30, 2013, 11:22:13 AM »
Yeah, a lot of people have recommended the HF jacks. It sounds like they do wear out quickly, mostly the seals in the hydraulic piston. It's tough...they are cheap enough that I could probably just replace them 5 times for the cost of a really good one...but at the same time the idea of buying something with the intent of throwing it away seems wrong lol.
I'll ask around on r3v. It would be a lot of fun to run these pieces myself, but at the same time I know I'd get better parts from a pro.
« Reply #43 on: September 27, 2013, 02:05:15 AM »
Finally, some progress pics. Round two of SLS prototypes has worked out well, and I am ready to get these suckers made up in metal. The fit is nearly perfect. At this point, inconsistencies in the castings of the FX-R projectors cause more variance in things than the adapters, so it's time to call it "good enough".
One big item I wanted to make sure of was the clearance between the projector lens and the headlight cover. To do this, I used some painter's putty since it doesn't contain abrasives.
*squish*
The thinnest part is 1.5mm, which is what was predicted from my measurements of the parts.
There is also 0.5-1.0mm of clearance between the lens retainer ring and the decorative chrome "smiley" cover. It is a bit warped, probably from decades of heat cycling, so it may take a little tweaking when I glue everything into place eventually.
Here is the projector attached to the 2nd generation SLS (3D print) prototype.
"Inside" of the adapter.
"Outside" of the adapter.
But bmwman, isn't that thing like, overly complex? What's with all the intricate nonsense? Well, it so happens that the price the 3D print house charges is directly proportional to the actual volume of the part. So, I modeled my adapter and then cored the hell out of it. They say that they can do a minimum wall thickness of 0.7mm, so I went with 1.4mm since you just aren't going to get consistent 3D print results when you are riding the limits. Warp, sag and undesired holes become issues when you push the wall thickness limit.
A solid one would have cost $37, and these were $23. Not bad for an extra 20 minutes of work.
These SLS parts are super strong. I didn't have an M4x0.7 tap handy, so I just drove the machine screws right into it. The part took the threads fine without splitting or anything. They are flexible and strong (surprisingly so). The material is nylon (sintered powder).
My next steps are to make a couple of final tweaks and then proceed to make (or maybe have a fab shop do it) the aluminum adapters. From there, I will be buying new bucket adjuster screws since the ones on these were shot, and then assembling + aiming the projectors. Since they are NOT sealed, I will be looking at my clearances in the headlight brackets and seeing about developing rubber boots to keep water and dust out of them. Worst case, I just use some aluminum tape to close things up, but I think that I can come up with something more OEM looking. I'll post up a concept / cartoon of what I am thinking of in a day or so.
colin86325
« Reply #44 on: September 30, 2013, 11:46:29 AM »
Looks fantastic!  I am sure you can probably fill any voids with epoxy if you are worried about strength.
