Author Topic: My FX-R Projector Retrofit Thread  (Read 33100 times)
« Reply #15 on: January 23, 2012, 03:16:32 AM »
Ok boys & girls, time for another update. I mocked-up a prototype adapter plate (it is usable, but there are some design changes I want to make now that I have the part in my hands).
My employer was throwing away some old manufacturing fixtures a couple of years ago, and I offered to take them off of their hands instead. These things were made with 120lbs (each!) of machined aluminum, in various bar & plate forms. So, needless to say, I have had close to 100lbs of aluminum plate laying around for years, waiting for me to do something with it. Anyway, I found a suitable piece & needed to trim it down for the adapter plate. I started with a bandsaw, but it was way too slow.
So I stuck it in a vise and milled it into shape!
Next, I needed to get the rotary table centered. This little dial gadget is super handy! Put it in a 1/4" collet, set the spindle to ~100RPM and adjust the X/Y position until the needle stops wobbling.
I got down to business & made all of the back-side cuts. The 3 larger holes in the row were used to set the center position of the work piece so that all of the various rounds could be cut.
Here it is, half-way done with the top-side operations. It didn't take much work since I had cut the inner profile perimeter already. Once I knocked ~.6" off of the inside, the middle bit fell right out!
The crappiest part of this was cutting the outer perimeter. It involved a delicate dance of milling, stopping to remove one bolt, milling, stopping to put it back, etc x 4. By the end, it was not holding the part securely. So, I cut my losses (no pun) and chucked it up on the lathe to clean it up.
All cleaned up, although it got taken down to 4.99" instead of the intended 5". Whatever, it is a prototype.
So, here is one. Whoever says you NEED a CNC mill is telling lies. With some effort, you can design most parts to be made manually. Hell, the digital position readout unit on the mill crapped out last year, and I ran this part without any electronic positioning at all. As long as you know what "backlash" is, you'll be fine. All you need is the ability to add & subtract in your head, and a decent dimensioned drawing. Oh, and calipers are a good idea, too!
So, how did it fit?
Well, it fit almost perfectly. Snug, with zero slop (much to my surprise). It does rotate ~0.5 degree thanks to an "oops" in the cutout for the city light, but radially there is no movement at all.
I will be taking the lessons learned here & making two more that should come out better. I did most cuts in a single pass, which is always a recipe for rough milled surfaces.
I will probably also mill a counterbore for the two mounting screws to get them flush (the heads would hit the FX-R projector assembly otherwise). I didn't account for the fact that a countersinking bit wouldn't fit here! I also plan to thin the outer ring by ~3mm (off of the outside) to get better clearance with the headlight bracket (it fits, but the rubber boot I plan to make would be really tight in there with this OD).
I also managed to get off by a couple of handle-turns down in the cut-out for the bi-xenon solenoid, and I forgot that the surface I was accidentally cutting through was a sealing surface.
Up by the city light, I started out being off by half of a cutter diameter in the radius. It's a common rookie mistake (and I'm a rookie at machining).
Lastly, there's a nibble in the outer perimeter from when I was cutting it out & the clamping wasn't quite adequate.
So, the next ones will be a lot cleaner. I'll probably do all cuts in 3 passes (-0.020", -0.005", 0.000"), spend more time with some of the centering setup, counterbore the 2 mounting holes, rough-cut the perimeter & finish it up on the lathe, and reduce the outer diameter by ~1/4". Yeah, it is probably overkill nit-picking this stuff. But, when you have the tools for it.....
« Last Edit: January 23, 2012, 12:24:35 PM by bmwman91 »
keflaman
  • -Receive: 35
« Reply #16 on: January 23, 2012, 07:06:54 AM »
I appreciate the amount of work and attention to detail you put into your projects and write-ups. I enjoy them very much.
Looking forward to watching you progress on this endeavor!
bwawuz02
« Reply #17 on: February 22, 2012, 06:48:42 PM »
Quote from: bmwman91;109126
had to ventilate the apartment like crazy before my fiancee got home & discovered that I had been putting car parts in the oven again lol)
priceless :D
Quote
I plan to stick the plastic low beam housings onto my lathe
As in personally owned, or one you have access to???
enildeR
  • lol ur face
« Reply #18 on: February 23, 2012, 12:29:25 PM »
just to be clear... the adapter is going to mate with the plastic housing with only epoxy/sealant? or are there going to be any screws?
« Reply #19 on: February 24, 2012, 03:02:59 PM »
Wow man. Thats dedication right there... I wish I could watch the actual process!
Sign me up for a pair of adapters if you decide to make a few.
« Reply #20 on: March 21, 2012, 07:15:45 PM »
How's this workin out?
« Reply #21 on: April 05, 2012, 12:48:44 AM »
Well, I still haven't gotten much done on this. A recent job change has me flying to Seattle every Sunday night & then back on monday night. On top of that, I have been having lots of rock climbing adventures on weekends since the weather has dried out. I need to find a saturday to dedicate solely to machining the adapter plates, and get to work on casting the weather seals.
Also, I am not 100% sure if I am keeping the car. I have a thread going in the Engine section about some recent timing chain issues. More and more, the car is starting to be less and less practical for my needs. It kills me to think about not being a member of the E30 community anymore and not having car projects, but at the same time I can't take the car on any sort of long drive without worrying the entire time. If I can find a reputable engine builder (or maybe go with a Metric Mechanic motor) and also have the tranny/diff overhauled, I think that the car might meet my worry-free reliability desires. We'll see. Until I get that sorted out, the headlight project is on hold!
« Reply #22 on: April 16, 2012, 10:29:22 AM »
Stay strong! Perhaps its time for a beater/daily?
« Reply #23 on: April 16, 2012, 04:13:43 PM »
Worry not, the car is getting a fresh motor, and I have every intention of finishing the lighting project!
My fiancee has been looking to replace her 2003 Civic. It still runs fine, so we might just keep it as the beater vehicle. Problem: solved.
jrobie79
« Reply #24 on: April 24, 2012, 09:47:01 PM »
hallelujah, cant wait for more progress
« Reply #25 on: April 25, 2012, 01:16:43 PM »
Yeah, me too. Hell, I just want a weekend where I have time to work on this at all now! Between wedding plans & business travel, I am way too short on time!
« Reply #26 on: April 27, 2012, 06:42:59 PM »
Congrats on the marriage dealio ;)
Hopefully she supports the hobby!!
« Reply #27 on: April 27, 2012, 10:41:36 PM »
Quote from: dude8383;112188
Haha, well "support" isn't necessarily the word. While the lack of AC and slightly noisy ride do annoy her a little, the has warmed up to the car over the last 6 years. She actually has fun when I take corners a little fast & stuff, and thinks that it is much safer than her Civic. She also knows that I enjoy pouring time and money into it, so in that respect she supports me. Besides...I get a MM motor, she has an excuse to go buy some silly purse or shoes or something lol. I definitely have the more expensive hobby though!
« Reply #28 on: May 07, 2012, 05:50:33 PM »
Quote from: bmwman91;112193
LOL. Well... that certainly is better than nothing! She doesn't drive it?
I do agree though, this hobby is incredibly expensive... I started doing track events 2yrs ago ago and the amount of money I've spent could have gone to better things but man... its like crack!
« Reply #29 on: May 07, 2012, 08:35:02 PM »
I have been teaching her to drive a stick, but her interest is a little low and I usually prefer to go do more fun stuff than give lessons. Back in college, I regularly taught girls to drive stick in the E30 since it was an easy way to break the ice and turn a drive into a date. It was also a quick way to weed out the girls that would freak out from a little pressure lol. I've never been a fan of drama queens!
« Last Edit: October 25, 2013, 03:46:02 PM by bmwman91 »
