Author Topic: deeznuts!!  (Read 2571 times)
jdirty
deeznuts!!
« on: September 02, 2011, 06:07:45 PM »
and bolts actually.
i'm about to replace my head pretty soon.
as soon as i figure how much parts i need for my upper timing case and thermostat housing though..
i've been skimming through realoem and bmwfans. but upon checking two diagrams for the upper timing case.. i can't seem to decipher how much bolts i needed and which ones really. real oem shows the part number i need and the updated part number that replaced it as well. (unlike bmwfans.. :mad:) but when i look at this diagram.. for part number 5.. it doesn't really say how many i need. as opposed to this diagram's #5.. they seem to be in the same spot too me.. but obviously have different part numbers..
i'm just trying to figure out what and how much bolts i need for the upper timing case housing and thermostat housing.
this is probably so simple right for people but my brain is running low after writing several papers for Psychology. T_T
deeznuts!!
« Reply #1 on: September 02, 2011, 08:28:41 PM »
+1 internets for the thread title.
Upper TC cover: 11 x  M6x35 bolts
T-Stat housing: 4 x M6x30 bolts
As for the timing case itself, I can't remember. It uses like 5 or 6 different ones. Are you replacing existing ones, or did you lose them? There isn't really any reason to replace the bolts.
deeznuts!!
« Reply #2 on: September 02, 2011, 08:30:29 PM »
Oh, and I would get a M6x1 helicoil / thread repair kit. At the very least, the valve cover threads in the head strip. I had a couple of threads in the timing case & front of the head go too, and thread repair was needed.
http://bmw.e30tuner.com/articles_vchc.php
jdirty
deeznuts!!
« Reply #3 on: September 02, 2011, 11:36:36 PM »
i just realized right now that i was looking at two irrelevant diagrams. i just needed the first diagram to look at since i just needed the upper tc bolts and the thermostat bolts.
replacing them seemed to be a must from what i remember when i was messing with them the last time. one of them even snapped inside the timing case..
i think my timing case itself is stripped. crap.
and yeah one of the vc threads were stripped on my old head.
Thanks for the info and the +1 internets!! :D
i love guides with pictures and you has a lot. your site is awesome.
deeznuts!!
« Reply #4 on: September 03, 2011, 06:25:50 PM »
For the record, masking off the whole head is probably unnecessary. If you go slowly you shouldn't spill any metal chips. Or, have a partner hold a shop vac hose where you are working to suck up the chips as they are produced.
jdirty
deeznuts!!
« Reply #5 on: September 12, 2011, 03:01:51 PM »
i don't plan on reusing the head so i'm not worrying too much about it. i'm crossing my fingers that it'll be sometime before i have to do such. :p
on a side note i had to order a new screw cap plug for my timing chain tensioner.
the damn thing got rounded. and now i don't really know how to take it off. ughh
