Author Topic: 318is racecar  (Read 9402 times)
rwinter
318is racecar
« on: August 29, 2011, 03:01:59 AM »
Colorado SCCA EP BMW E30 318is race car. Also fits in NASA GTS3. Rebello engine- dyno'd 230HP at 7400RPM- solid lifters and built to limit of SCCA rules. Rebuild was 5 years ago. 2020lbs. Not a street car. 1 3/4 x 1/8" cage which ties into suspension pickup and rear subframe. Cage is one size stronger than req'd for this weight car. Fiberglass front fenders, hood, deck lid. Lexan windows. Electromotive tec3R engine controller, wideband O2 sensor running closed loop with controller. JB racing aluminum flywheel with Spec 4-puck clutch, both with one weekend on them. '95 325 tranny with 1:1 5th gear. 325 diff, 4.x:1, Quaiffe limited slip. Diff built by Bimmerhaus. 8 Kosei 15" x 7 wheels. 1 set of BFG R1s, one weekend on them, purchased 08/2011. Tilton dual master setup with balance bar, tilton clutch master. New ATL fuel cell liner this year. New rt side and left side nets. Paul Yaw custom front and rear suspension, fully adjustable. Fire system. Fun little car. Diced it up with E36 M3s at the track just last weekend. Low 2:12s at High plains raceway in Colorado on DOT tires. I can take some photos if people are interested, I don't have any recent.
$14500.
e9nine
318is racecar
« Reply #1 on: August 29, 2011, 10:28:09 AM »
Not in the market now but would like to see any pics of the setup you have for sale.
Any summary on what the Rebello motor comprises of? Sounds like a wicked set up!
318is racecar
« Reply #2 on: August 29, 2011, 04:51:36 PM »
That does sound pretty wicked..details!
rwinter
318is racecar
« Reply #3 on: August 30, 2011, 01:22:38 AM »
thanks to both you guys! Lets see.. 11:1 compression, J and E pistons, Calico coated bearings, custom baffled oil pan, Custom fittings welded in for oil cooler plumbing, Chevy Camaro 5.0 radiator (cheap, very light, and never runs hot), setrab oil cooler, custom headers, 450cc injectors. He's pretty secretive about the cams, I had some chicken scratches that it had duration 268/264 at .050. If you don't know what an electromotive Tec3r controller is, it is full engine control- everything is programmable, ignition and fuel. Its amazing all the different tables and graphs and settings.  Wide band feedback to the controller works great. Neat wideband LED gauge keeps you updated that mixture is right. Uses two electromotive coils. Front crank damper is custom of my own design, will not come apart like the stock ones can. This engine spins to 8k rpm. Going uphill, it gains nicely on E36 M3s. I will get some pics, but not for at least a few days.
Warsteiner
  • -Receive: 21
318is racecar
« Reply #4 on: September 06, 2011, 06:22:09 PM »
rwinter.....sent you a PM
~Ralph
longms
318is racecar
« Reply #5 on: September 08, 2011, 10:33:49 PM »
Bump for pics of this beast!!!!!!!!
Matt-B
  • Administratorz
318is racecar
« Reply #6 on: September 13, 2011, 04:41:00 PM »
Useless thread with no pics. Please post pics or will lock thread
-mA+t B
longms
318is racecar
« Reply #7 on: September 14, 2011, 11:53:13 AM »
Please don't let him lock the thread. I really want to see this beast
rwinter
318is racecar
« Reply #8 on: September 15, 2011, 12:18:56 AM »
Lock the thread really? I've been busy and the car is on jack stands right now. I just tried to upload 2 pics to hold people over, each below 500kb and I got "upload failed". Sorry. I guess maybe I'm locked out..?
longms
318is racecar
« Reply #9 on: September 16, 2011, 12:08:29 PM »
I highly doubt it. He was probably joking. Try again whenever you get a chance
rob_e30
318is racecar
« Reply #10 on: September 16, 2011, 02:25:46 PM »
Quote from: longms;106668
You don't really expect to see the word "beast" and "318" in the same sentence.
wazzu70
  • Nasty Nick
  • -Receive: 18
318is racecar
« Reply #11 on: September 16, 2011, 09:02:20 PM »
If you email pictures to me I can host them for you. I sent a PM with my address.
-Nick
91 E30 M42 with VEMS
318is racecar
« Reply #12 on: September 17, 2011, 07:38:24 AM »
I post my pics to Photobucket or Picasa & link them in.  Em-bed-ded pics have been broken or disabled via some setting that I'm not smart enough to figure out...  Sorry for the inconvenience.
AutoXSS
318is racecar
« Reply #13 on: September 18, 2011, 04:31:27 PM »
I'm tuned in for pics.......
wazzu70
  • Nasty Nick
  • -Receive: 18
318is racecar
« Reply #14 on: September 20, 2011, 03:03:46 PM »
Pictures of Robs car:
« Last Edit: September 21, 2011, 01:26:23 AM by wazzu70 »
-Nick
