Author Topic: Fuse #23, No it is not the red/gray wire and the HU has been in for 8 months.  (Read 3730 times)
AtlBMW
So started blowing #23 and have now been through 2 packs of fuses during diagnosis. Red/Gray in the dash has a connector but is connected to another red/gray and continues in the harness. It is not connected to the head unit. Promise.
The plot thickens. At first I could turn on running lights and no pop. Only once I pulled the switch all the way out and turned the headlights on, did I get a pop.
Than after some pulling bulbs, inspecting connections, cleaning etc. I could pull the switch all the way out, running lights and headlights and not pop. Only when I started the car did I get a popped fuse.
Than I pulled the right license plate light only to find the the brown wire is not connected and it appears the the unprotected connector is flopping around in the fascia. BINGO I think!
So attach connector, and now the fuse blows as soon as I pull the switch to the first, running light, position.
Like I said I have tried to systematical trouble shoot this puzzle but I am tired of buying fuses as well as making things worse.
Any advice?:confused:
AtlBMW
any advice or direction on where to go or how to diagnose with this multimeter?
AtlBMW
Cleaned up the wires leading to the front fog and all is good again.
Slick92GS-R
good to hear that all is well  .. Electrical nightmares are nightmares ..
