So started blowing #23 and have now been through 2 packs of fuses during diagnosis. Red/Gray in the dash has a connector but is connected to another red/gray and continues in the harness. It is not connected to the head unit. Promise.
The plot thickens. At first I could turn on running lights and no pop. Only once I pulled the switch all the way out and turned the headlights on, did I get a pop.
Than after some pulling bulbs, inspecting connections, cleaning etc. I could pull the switch all the way out, running lights and headlights and not pop. Only when I started the car did I get a popped fuse.
Than I pulled the right license plate light only to find the the brown wire is not connected and it appears the the unprotected connector is flopping around in the fascia. BINGO I think!
So attach connector, and now the fuse blows as soon as I pull the switch to the first, running light, position.
Like I said I have tried to systematical trouble shoot this puzzle but I am tired of buying fuses as well as making things worse.
Any advice?:confused:
