Author Topic: Just Picked Up 1994 318i with only 98,000  (Read 3172 times)
Ran035
« on: July 15, 2011, 01:18:47 PM »
I just picked up a 1994 318i with 98,000 miles. The only  problem need a head gasket, I will start working on it today. I think I got a good deal, has new brakes and rotors, belts, therostat, etc. The inside of the car is like new. I paid 1100. What do you think?
e30boarder
« Reply #1 on: July 15, 2011, 01:30:40 PM »
sounds good... i think you should post some pics :)
« Reply #2 on: July 15, 2011, 08:39:52 PM »
Make sure you get that head checked thoroughly for straightness and flatness.  If it's cracked or warped the only way to fix it is to get it machined or replaced.  Pressure test the cooling system while you're at it...the rad, water pump, profile gasket and intake preheating system are all pretty weak.
Even if it does have a cracked head it still sounds like a good deal.
Ran035
Repairs
« Reply #3 on: July 25, 2011, 09:56:50 AM »
I had the Head repaired, Crack in the number 2 Cylinder. Put engine back together, the car still over heats, I think I have air in the system. I will try bleeding more today. Any help would be great...
sqlpython
« Reply #4 on: July 25, 2011, 01:38:55 PM »
Quote
  What exactly do you mean by the above....?
Was the Head Cracked, the block or the Piston..?
And how exactly did you repair?
`93 E36 BMW 318i sedan
dakon
« Reply #5 on: July 25, 2011, 11:58:19 PM »
Right by Number 2 cylinder there is a large coolant channel that is very prone to cracking on the M42 head...
read this.
http://www.m42club.com/forums/showthread.php?t=13442
Ran, is your fan clutch good? have you tested it?
did you have your head pressure checked after it was "repaired" ?
did you pressure check your coolant system before filling the system?
when you bled the system, did you have someone bring the car to around 1500rpm, to get the system up to close to full operating pressure?
I went though this same nightmare you are going though about 6 months ago.. My head had 2 cracks.. and i also had a bad fan clutch...
Ran035
Cars running great.
« Reply #6 on: August 01, 2011, 01:07:26 PM »
It was air in the system, once I got it out the car does not over heat. The car is running great. Just want to thank everyone for there help. Randy
