Author Topic: Anyone Have the "AFM Extension Cord" On Their Car?  (Read 2204 times)
« on: July 10, 2011, 12:01:04 PM »
I've noticed that some M42 AFMs have an extension cord thingy between them & the ECU harness. If you have one, can you do me a favor and look inside the male end (the end of the extension that plugs into the ECU harness) and either take a picture of the numbers, or post the BMW PN in here? It would also be cool if you could pull back the rubber boot & post the AMP PN molded onto the back side. Thanks!
« Reply #1 on: July 10, 2011, 12:13:56 PM »
I pulled mine when I got the car to troubleshoot a no-start issue.  It was waterlogged & setting AFM 1915 errors.  If I can dig it out I'll get the info for you later today.
« Reply #2 on: July 10, 2011, 12:30:24 PM »
BMW 1 734 516.3 (Bosch 1 284 463 500)
Female pin socket (AFM side):
BMW 171812 6
AMP 928635-1 (center) also 828709-1 (case)
Male pin socket (harness side):
BMW 17181 25
AMP 828710-1
« Reply #3 on: July 10, 2011, 02:42:16 PM »
Sweeeeet. Thanks! I think that this MAF kit will end up being plug & play after all.
« Last Edit: July 10, 2011, 02:59:29 PM by bmwman91 »
