Author Topic: coolant system help  (Read 3198 times)
e30boarder
coolant system help
« on: July 09, 2011, 11:41:36 AM »
I have a volvo 850 radiator fan hooked up to my m42 right now. I have it hot wired in so its constantly running (just temporary). I was having some issues with my temp switch but I think it was due to the coolant system not being bled properly. Its good now... when Im cruising down the road the needle never goes past 1/2 mark on the temp gauge. But sitting in traffic is a different story. Its crept up to the 3/4 mark I think twice since I got the car back on the road... I thought it was due to the AC being on, but this morning it did it again with no AC. I need to wire in the fan properly to really tell if its a problem. Its supposed to be a 2 speed fan but I havent seen the second speed kick on... probably due to my hack wiring job. Basically I just want to know if I should find a new fan or should I keep pluggin away with this one? I'm hoping that if I wire it in properly, I'll get some better results. I have the lower temp switch in the radiator. I also removed the AUX fan. I'm using that to power the volvo fan. Do I need to use the 2 speed relay from the AUX fan? Ive seen the 2 threads that have the volvo fans setup... and they said there's worked fine so I'm guessing I'm just paranoid. I read somewhere else that someone eliminated the mechanical fan and replaced his stock aux fan and just ran it like that with no problems. I'm willing to go a different route if necessary. I just want the car to stay cool. Ideas?
e30boarder
coolant system help
« Reply #1 on: July 09, 2011, 03:23:08 PM »
nevermind.. it was my hack wiring job. its working fine. i just need to get the temp switch sorted out.
PumpItUp
coolant system help
« Reply #2 on: July 09, 2011, 08:55:09 PM »
can you post pictures? i'm interested in how the volvo 850 fan is sitting.
e30boarder
coolant system help
« Reply #3 on: July 09, 2011, 10:22:07 PM »
Lol sure. I have it zip tied in for right now. It definitely needs more work but it keeps it cool so I'm happy with the result. Ill take some pics tomorrow
stillmatick
coolant system help
« Reply #5 on: July 10, 2011, 09:31:54 PM »
hey where can i get a cone filter?
e30boarder
coolant system help
« Reply #6 on: July 11, 2011, 09:17:13 AM »
i think i got mine at pepboys
