DISCUSSION
General Topics
Brake Caliper? Girling? ATE? Either?
Topic: Brake Caliper? Girling? ATE? Either? (Read 2749 times)
Colo318IS
Jr. Member
July 01, 2011, 03:08:21 PM »
Hello-
So I need to replace my front brake calipers....does anyone know...do we have girlings or ATE or can either be used?
Thanks so much for your insight.
Jay
KenC
Sr. Member
July 01, 2011, 04:53:25 PM »
You can use either, but I believe all 318is came with Girling. I'd suggest just rebuilding them; it's easy and cheap.
Administrator
Legendary
-Receive: 60
Lives in the 80s
July 01, 2011, 08:49:17 PM »
Mine has Girling too. I'd rebuild both...the kits are only like $15 IIRC.
I'd also strongly suggest doing whatever you decide to both calipers at once, especially where the front brakes are concerned.
Gerta318is
Sr. Member
-Receive: 2
July 02, 2011, 09:02:21 PM »
OP - you can check out Pelicanparts.com or Bluntech.com ... both have rebuild kits for reasonable cost.
Colo318IS
Jr. Member
July 10, 2011, 11:10:19 PM »
Ok, great, thanks so much...I did some research on the rebuild and believe I will go that route...I did double-check mine and found out they are girlings just for the record. Thanks so much!
DISCUSSION
General Topics
