Author Topic: Brake Caliper? Girling? ATE? Either?  (Read 2747 times)
Colo318IS
« on: July 01, 2011, 03:08:21 PM »
Hello-
So I need to replace my front brake calipers....does anyone know...do we have girlings or ATE or can either be used?
Thanks so much for your insight.
Jay
KenC
« Reply #1 on: July 01, 2011, 04:53:25 PM »
You can use either, but I believe all 318is came with Girling. I'd suggest just rebuilding them; it's easy and cheap.
« Reply #2 on: July 01, 2011, 08:49:17 PM »
Mine has Girling too.  I'd rebuild both...the kits are only like $15 IIRC.
I'd also strongly suggest doing whatever you decide to both calipers at once, especially where the front brakes are concerned.
Gerta318is
« Reply #3 on: July 02, 2011, 09:02:21 PM »
OP - you can check out Pelicanparts.com or Bluntech.com ... both have rebuild kits for reasonable cost.
Colo318IS
« Reply #4 on: July 10, 2011, 11:10:19 PM »
Ok, great, thanks so much...I did some research on the rebuild and believe I will go that route...I did double-check mine and found out they are girlings just for the record.  Thanks so much!
