Author Topic: water leaking in threw sunroof, and passenger side door.  (Read 5645 times)
92BMW318is
« on: June 28, 2011, 08:04:32 PM »
i was thinking about filling the plastic moulding that weather proofs the window with some of that silicone adhesive shit that comes in a cocking tube.
as for the sunroof it leaks in the back corner and then the water poors down by the passager window. is the like a drainage resivor or somthing for the water that leaks through or is it just suppose to seal it all out.
« Reply #1 on: June 28, 2011, 08:19:37 PM »
There should be four drains for the sunroof.  One is blocked or disconnected - drop the roof panel & re-connect.  Hopefully it's not rusted out.
I've sealed cars in the past...my e30 had a leak in the trunk that I sealed up that way.
92BMW318is
« Reply #2 on: July 07, 2011, 08:09:58 AM »
yeah it was just a hose on the sun roof...
used that silicone adhesive  on the pasanger side window weather strips and it worked like a dream thanks for your response
« Reply #3 on: July 07, 2011, 06:23:30 PM »
Anytime.  That's what I like to hear though, someone keepin' another one running!  A plugged sunroof like that will rust the car from the top down...I've seen a lot of BMWs (especially e30s) with rusted out sunroof panels.
rjcaptsean
« Reply #4 on: July 10, 2011, 03:13:39 PM »
While you are looking for leaks, you might want to check out your elephant trunk drain which is located on the engine firewall on the passenger side. I was getting wet floorboards on the passenger side and the sunroof drains were fine. A bit of forum checking brought me to that drain.  Both of my cars looked like this:
And now it's dry as a bone in the pax compartment.  Happy days
