Author Topic: Oil Filter Housing Leak  (Read 2425 times)
ClayW
« on: June 27, 2011, 08:34:08 AM »
I've recently developed a BP-sized oil leak at my oil filter housing. I've read the posts from owners that point out the O-ring as the likely culprit. I've ordered a new gasket, O-ring and even a new oil pressure switch.
Am I missing anything?
Project Blogs:
1967 BMW 1600 w/M42: www.tx02.blogspot.com
1991 BMW 325i DD: http://www.r3vlimited.com/board/showthread.php?t=266953
rjcaptsean
« Reply #1 on: June 27, 2011, 02:37:45 PM »
There is also an O-ring on the bolt that holds the cap on.  Normally when you buy a new filter, it will come with both.  I assume you are going to remove the housing from the block since you ordered a gasket.  Hopefully when you clean it up you can look for cracks in the aluminum housing.
monty23psk
  • -Receive: 17
« Reply #2 on: June 27, 2011, 03:29:43 PM »
I just did this and still have a little oil, but figure it is my pressure switch. I am waiting for it as the washer might be bad. But I was leaking a lot before and now just a little after swapping the oring and paper gasket. I used a little sealent swith gasket also for extra proctection. Do you have a small pool on the block behind the pressure switch? Also if the housing cap is leaking, then it is the oring as stated above that comes with the new filters.
