Author Topic: My overheating continues.....  (Read 2746 times)
ClayW
« on: June 01, 2011, 04:10:20 PM »
I am running at about 99C consistently.
I have an M42 in a `67 1600 with a new water pump, thermostat and radiator. At the moment, there is no heater and I am confident that the system in bled completely.
Any ideas?
Project Blogs:
1967 BMW 1600 w/M42: www.tx02.blogspot.com
1991 BMW 325i DD: http://www.r3vlimited.com/board/showthread.php?t=266953
M5wanaB
« Reply #1 on: June 01, 2011, 06:57:41 PM »
any check engine lights? how are you confirming the 99c temp? are you running coolant or just water?
« Reply #2 on: June 01, 2011, 07:38:56 PM »
That does seem a bit hot, but mine will idle that high in traffic.  Fans are working, right?
Pressurized coolant has a high boiling point though.
ClayW
« Reply #3 on: June 02, 2011, 10:28:56 AM »
99C is extrapolated from the reading on the stock 2002 gauge. I borrowed an IR gun to confirm. Will report back soon on the findings.
Yep, the fan is working. I have it on a manual switch at the moment.
Project Blogs:
monty23psk
  • -Receive: 17
« Reply #4 on: June 02, 2011, 11:36:55 AM »
Do you have the fan clutch installed? Can't remember from pics. Also what Aux fan you using, OEM or aftermarket? Is it only low or high? I saw your other post about the AC. AC running will cause the engine to run much hotter FYI.
ClayW
« Reply #5 on: June 02, 2011, 11:47:15 AM »
Quote from: monty23psk;104299
I have no mechanical fan, rather a 16" electric fan at full speed.
Project Blogs:
monty23psk
  • -Receive: 17
« Reply #6 on: June 02, 2011, 12:54:29 PM »
A puller I assume if mounted between engine and radiator. I guess you need to confirm temp and then compare that to the middle reading on the e30 gauge, which seems to be normal. I believe it was stated in the other posting. Also make sure the temp sender for the guage is working correctly.
