Author Topic: camshaft help  (Read 2708 times)
tommymac75
camshaft help
« on: April 10, 2011, 05:10:46 PM »
OK so i am looking for a set of cams for my 97 z3 with a m44... i know it isnt a m42 but this page is the closet i could find that might help. i know cat and vac make cams just looking for other options
Cristian G in Oz
camshaft help
« Reply #1 on: April 12, 2011, 07:35:57 AM »
If you dont have any luck here you could always try over at http://www.318ti.org, they have good info for M42 and M44 cars based around compacts though.
I believe you could get a set of Schrick Cams if your cashed up. Also Cat Cams do M44 and M42 cams.
Don't try and fit M42 cams to the M44,  They are different in a big way.
Hope this helps.
Cristian
1990 318is
autox320
  • -Receive: 2
camshaft help
« Reply #2 on: April 13, 2011, 01:55:39 AM »
Could call Delta or Elgin.
Delta did ours after a couple phone conversations I mailed them a used set of M42 cams. They were welded up and reground to the profiles of a S52 3.2L M3 camshaft (Duration 252 / Lift 10.2)
Toby B
camshaft help
« Reply #3 on: April 15, 2011, 12:42:25 AM »
latest poopy from Delta is that they don't feel comfortable welding the hollow cams
any more...
http://bmwpugetsound.com/vbb/showthread.php?t=45204
