Author Topic: FS: S50 Pistons and Rings  (Read 5652 times)
flyingbrickperformance
    • http://www.flyingbrickperformance.com
« on: April 10, 2011, 07:32:35 AM »
I have a complete set of S50 pistons and rings for 4 of them for anyone doing a project that would be able to make use of them - they're 86mm bore.  Will post pics soon.  I paid $150 shipped with the new rings so looking to get as close to this as possible.
Warsteiner
  • -Receive: 21
« Reply #1 on: April 10, 2011, 10:13:41 AM »
This is a great deal guys. Someone should jump on this! New rings will run you $100+ shipping alone.
Cheers,
~Ralph
« Reply #2 on: April 12, 2011, 08:07:34 AM »
Nobody wants these?
« Reply #3 on: April 27, 2011, 08:11:34 PM »
Here are some pics of the pistons and rings for sale.
http://s1183.photobucket.com/albums/x463/dateague/Car%20Parts/
1998ccc
  • -Receive: 6
« Reply #4 on: April 27, 2011, 09:39:33 PM »
Quote from: flyingbrickperformance;102976
Nobody wants these?
You're not alone.  Nobody will buy my S52 pistons either.  Let's hope it's just tax season.
chapellej
« Reply #5 on: April 27, 2011, 11:55:03 PM »
so what would be the advantage, would i need to bore the piston chambers to use these?
e36 m42 project.....
« Reply #6 on: April 28, 2011, 07:21:11 PM »
Yes, you'd need to bore them to 86mm.  Advantage is "there's not replacement for displacement" when making power (at least the non-aspirated kind).  Can also be used as the basis for stroked m42 variants.
chapellej
« Reply #7 on: May 06, 2011, 11:25:14 PM »
what would i need as far as head gasket, and crank to use these i am sure this can be searched but would a m47 crank work? and mls head gasket for deck clearance at the top? i am very interested in this.
Warsteiner
  • -Receive: 21
« Reply #8 on: May 07, 2011, 07:34:29 AM »
Recipe for S50 pistons: Bore block to 86mm, get M44 2.04mm HG, Deck the piston 2.65mm, cut valve reliefs into pistons, get a set of 138mm connecting rods, attach to a M47 crank and away you go! A perfect set up. Minor machining on the crank.
Then you have to option of lightening valve train parts and porting the head for power.
A major write up coming soon....
Cheers,
~Ralph
« Reply #9 on: May 07, 2011, 09:24:36 AM »
I wish I had the cash to try this out...an M47 crank is worth more than my whole car...:(
chapellej
« Reply #10 on: May 07, 2011, 10:34:18 AM »
Quote from: Warsteiner;103613
Cheers,
~Ralph
suscribed!!!!
wannam42
« Reply #11 on: September 05, 2011, 12:13:26 AM »
Still available?
accota
« Reply #12 on: December 21, 2011, 06:40:41 PM »
Are these us or eur s50b30 pistons?
