Author Topic: What hose goes here?  (Read 3391 times)
ClayW
  • -Receive: 2
« on: April 03, 2011, 09:45:43 AM »
I have a spare vacuum port on the throttle body after I cleaned up the mess under the intake, thanks to this thread.
So, what should I put here? Plug it, maybe?
Otherwise, does anyone see anything amiss so far?
« Last Edit: April 03, 2011, 09:48:03 AM by ClayW »
Project Blogs:
1967 BMW 1600 w/M42: www.tx02.blogspot.com
1991 BMW 325i DD: http://www.r3vlimited.com/board/showthread.php?t=266953
« Reply #1 on: April 03, 2011, 10:12:59 AM »
I think that one goes to the vacuum canister.
a930rocket
« Reply #2 on: April 03, 2011, 10:16:28 PM »
+1
1991 318is
1987 911 Turbo
ClayW
  • -Receive: 2
« Reply #3 on: April 03, 2011, 10:30:36 PM »
Quote from: DesktopDave;102788
What vacuum canister? Is it necessary?
Forgive me; I'm new to the M42 world and I didn't remove this engine from its donor car.
Project Blogs:
« Reply #4 on: April 03, 2011, 10:46:34 PM »
There's a purge valve and a vac can under the P/S reservoir on the stock car.  If you don't have a vapor recovery system off the gas tank you have little need for it.  I'd plug it if that's the case.
ClayW
  • -Receive: 2
« Reply #5 on: April 04, 2011, 07:36:01 AM »
Perfect. Thanks!
Project Blogs:
a930rocket
« Reply #6 on: April 04, 2011, 11:32:53 AM »
Here's a pix of the canister. It has a short piece of hose (with a one way valve I'm guessing) and then runs to the TB.
1991 318is
1987 911 Turbo
aworthybrother
« Reply #7 on: April 04, 2011, 03:47:24 PM »
Here's a btter illustration...
ClayW
  • -Receive: 2
« Reply #8 on: April 14, 2011, 08:17:50 AM »
Holy Throttle Body buildup, Batman!
Thanks, fellas.
Project Blogs:
