DISCUSSION
Engine + Driveline
What hose goes here?
Topic: What hose goes here? (Read 3382 times)
ClayW
-Receive: 2
April 03, 2011, 09:45:43 AM »
I have a spare vacuum port on the throttle body after I cleaned up the mess under the intake, thanks to
this thread
So, what should I put here? Plug it, maybe?
Otherwise, does anyone see anything amiss so far?
Last Edit: April 03, 2011, 09:48:03 AM by ClayW
Project Blogs:
1967 BMW 1600 w/M42:
www.tx02.blogspot.com
1991 BMW 325i DD:
http://www.r3vlimited.com/board/showthread.php?t=266953
Administrator
Legendary
-Receive: 60
Lives in the 80s
April 03, 2011, 10:12:59 AM »
I think that one goes to the vacuum canister.
a930rocket
April 03, 2011, 10:16:28 PM »
+1
1991 318is
1987 911 Turbo
ClayW
-Receive: 2
April 03, 2011, 10:30:36 PM »
Quote from: DesktopDave;102788
What vacuum canister? Is it necessary?
Forgive me; I'm new to the M42 world and I didn't remove this engine from its donor car.
Project Blogs:
1991 BMW 325i DD:
Administrator
Legendary
-Receive: 60
Lives in the 80s
April 03, 2011, 10:46:34 PM »
There's a purge valve and a vac can under the P/S reservoir on the stock car. If you don't have a vapor recovery system off the gas tank you have little need for it. I'd plug it if that's the case.
ClayW
-Receive: 2
Reply #5 on:
April 04, 2011, 07:36:01 AM »
Perfect. Thanks!
Project Blogs:
1991 BMW 325i DD:
a930rocket
Reply #6 on:
April 04, 2011, 11:32:53 AM »
Here's a pix of the canister. It has a short piece of hose (with a one way valve I'm guessing) and then runs to the TB.
1991 318is
1987 911 Turbo
aworthybrother
Reply #7 on:
April 04, 2011, 03:47:24 PM »
Here's a btter illustration...
ClayW
-Receive: 2
Reply #8 on:
April 14, 2011, 08:17:50 AM »
Holy Throttle Body buildup, Batman!
Thanks, fellas.
Project Blogs:
1991 BMW 325i DD:
DISCUSSION
Engine + Driveline
