Author Topic: Removing cloth from my seats?  (Read 4235 times)
DarioM42
« on: March 10, 2011, 08:27:48 AM »
Is it possible to remove cloth from seats withouth damage and wash it in wash machine?
Did anyone did it?
DarioM42
« Reply #1 on: March 10, 2011, 09:59:52 AM »
Is it at all possible to remove complete cloth from the seat an put it back on without damage?
jscribble
« Reply #2 on: March 10, 2011, 10:39:37 AM »
There is a thread floating around in which a member (from Florida?) reupolstered his entire car, turned out great, probably likely you could remove although I would be skeptical of machine washing...
Try the search, if I come across it, I'll edit this post.
Betty - Sold
Sabine - 2004 325xi
« Reply #3 on: March 10, 2011, 05:27:16 PM »
That fabric is not meant for a washing machine.  There are a lot of fabric cleaners that will help it out tremendously without dismantling the whole seat.
If that didn't work, I might be tempted to overhaul the seat...while that's going on (fixing welds, replacing pneumatics & trim, etc) I'd pull the hog rings & get it dry cleaned.  It'll turn out better and likely not get destroyed.  With either method, I'd e sure to clean a sample first just to be sure.  New covers are still available from BMW, but they're about $500 per seat.
DarioM42
« Reply #4 on: March 11, 2011, 08:20:14 AM »
Jscribble, I found that post when member reupolstered his entire car, because I have read all posts in Interior subforum, here it is :)
http://www.m42club.com/forums/showthread.php?t=9489
DesktopDave I think you are right, my original cloth is in good condition and I'll go with some fabric cleaners, but I just want them to be closest to new condition, so that's the reason why I thought about washing...
jscribble
« Reply #5 on: March 11, 2011, 10:02:22 AM »
I imaging you could hand wash, remove, soak (moderately) and hand scrub with carpet cleaner or something similar. You could also treat with scotch-guard and help keep it in it's newly shiny shape for a while longer.
I just want to throw in some recaro buckets, replace carpeting and see if I can cut some ABS plastic for door panels like I had on my jeep.
Post some pics if you attempt any sort of removal. Likely more than a few members would be interested in trying it.
Betty - Sold
Sabine - 2004 325xi
DarioM42
« Reply #6 on: March 12, 2011, 05:36:13 PM »
I give up for now to remove my fabric, I'll use some fabric cleaners, and see how it will look...
