Just a quick question about the DASC Kit and it's performance increase. My research shows that applying this kit to a standard M42 engine will give an increase of approx. 60% in both power and torque. would this be accurcate?
here are some results of Power/Torque increase on a M44 powered 318iS with the DASC, as seen in
"101 Performance Projects for your BMW: 3 Series 1982 - 2000" by Wayne R. Dempsey
Stock Power: peak ~138hp (103kW)
Stock Torque: peak ~125ft-lb (175Nm)
SC Power: peak ~220hp (169kW)
SC Torque: peak ~175ft-lb (230Nm)
just curious if these are correct? if so, by applying the DASC to the MM 2100 FI Rally engine (205hp, 225Nm) the power would increase to well over 300hp!! very much excited to hear your opinions on this.
Cheers,
Jester
