Author Topic: Weird problem  (Read 3409 times)
Meister
Weird problem
« on: September 27, 2006, 10:20:06 PM »
Hi
I am having a strange problem with my car ('91 318iS).  I got gas one night and on my way home I heard a noise, didn't really think anything of it at the time, anyway over the next couple days, my car started to jerk a lot while driving and my check engine light would flash.  I thought maybe it was just some bad gas so I put some gas treatment in and it helped out alot but only for a day.
Anyhow, now the jerking is really bad to where I can't even drive it.  Also, when my car idles, sometimes it will drop the rpms really low and almost die but then it comes back up to normal.  Sometimes it will just die though.
Anyone have a guess to what could be causing this?
kowalski
  • El\' Duder
Weird problem
« Reply #1 on: September 28, 2006, 04:55:17 AM »
http://www.m42club.com/forums/showthread.php?t=439
turn the key to the on possition and push the gas pedal all the way to the floor and let it back out 6 or 8 times, i forget how many it is... do it fairly fast and then the light will blink out the codes for you.
Sale:
Fore Sale Thread
romkasponka
Weird problem
« Reply #2 on: September 28, 2006, 05:02:37 AM »
5 times
E30 318is M42
E36 318is M44
Meister
Weird problem
« Reply #3 on: September 29, 2006, 07:30:35 AM »
Cool thanks, I'll have to give this a try when I get a chance
Meister
Weird problem
« Reply #4 on: October 02, 2006, 12:39:12 PM »
Quote from: kowalski
I gave that a try and my engine light blinked out "1288" but I did not see that code in the list?
dbgrubbs
Weird problem
« Reply #5 on: October 02, 2006, 12:57:31 PM »
Washed your engine bay recently? Water in the spark plug wells will cause this (among other things).
Weird problem
« Reply #6 on: November 26, 2006, 01:51:01 AM »
So, you have any luck figuring out the problem?
silverblades181
Weird problem
« Reply #7 on: November 26, 2006, 10:08:33 PM »
how old are your gas pump and gas filter?
E30 318is 1991 (Brilliantrot)
Bayerisch Motoren Werke
Weird problem
« Reply #8 on: November 26, 2006, 10:43:05 PM »
Filter has a few thousand miles on it.  The pump...probably original.  I have though it might be the pump...but it seems too intermittent to be that.  Who knows.
Meister
Weird problem
« Reply #9 on: November 27, 2006, 03:34:29 AM »
I got my problem fixed.  It turned out that 3 of my coil packs were bad, 2 were leaking spark and 1 was cracked.
