Author Topic: M42 Fuel Requirements?  (Read 3827 times)
ClayW
« on: February 28, 2011, 07:25:12 AM »
What are the M42's fuel pump needs (lph/gph and psi/bar)?
I am trying to select an external electric fuel pump. My M42 is going into a `67 1600 and the E30 318is in-tank pump fits, but is too short to pick up all the fuel in the tank.
Thanks in advance!
Project Blogs:
1967 BMW 1600 w/M42: www.tx02.blogspot.com
1991 BMW 325i DD: http://www.r3vlimited.com/board/showthread.php?t=266953
ClayW
« Reply #1 on: March 01, 2011, 07:42:14 AM »
Nothing? Does anyone know?
Project Blogs:
B318M42W
« Reply #2 on: March 01, 2011, 09:53:09 AM »
just modify the hanger and make it longer? find a good piece of injection hose that can be submerged into fuel (to replace the " orange box"), add the length you need to the hanger, add a collar to hold the pump in position and you,re basicly done
M90 Blown M42 :cool:
romkasponka
« Reply #3 on: March 01, 2011, 07:09:20 PM »
IMHO walbro 392 is the best choice, except Bosch 044 ;)
E30 318is M42
E36 318is M44
ClayW
« Reply #4 on: March 11, 2011, 09:34:47 AM »
Quote from: B318M42W;101884
Even if I can modify the pick-up, the fuel gauge won't be accurate.
Project Blogs:
B318M42W
« Reply #5 on: March 11, 2011, 11:23:00 AM »
how is the fuel level sender mounted in the tank in the 1600??
ClayW
« Reply #6 on: March 15, 2011, 09:54:44 AM »
Quote from: B318M42W;102175
It's in-tank, mounting in the same fashion as the 318is pump. 1600's and 2002's use a mechanical fuel pump, so it's just the sender in the tank.
The E30 318is fuel pump works great for the conversion and drops right in; the problem is that the E30 pumps and senders are about an inch too short for the 2002/1600 fuel tank, leaving a gallon or two of unusable fuel in the tank.
Project Blogs:
pdxmotorhead
« Reply #7 on: March 15, 2011, 04:58:57 PM »
If you lower the pump, youll just have a 2 gal "reserve" ,, or I've lengthened the arm for the gauge before to change its range... You might check out a 318ti sender, its got 2 because the tank straddles the drive line...
Dave
B318M42W
« Reply #8 on: March 15, 2011, 11:57:12 PM »
just thought about something... i'm not sure if the E30 325 has an external fuel pump?
http://www.realoem.com/bmw/showparts.do?model=1413&mospid=47322&btnr=16_0181&hg=16&fg=15&lang=enUS   #9 in the diagram.   could someone clear that up???
pre-supply pump and then another pump???
