Author Topic: wtb: m20 flywheel/clutch/starter  (Read 3879 times)
jakeb
« on: February 14, 2011, 11:23:29 AM »
Looking for a m20 flywheel or 323, clutch, and a m20 starter to do the swap onto a m42.
TIA, jake
http://www.classicdaily.net - swapping this into that
http://www.blunttech.com - all your parts needs
« Reply #1 on: February 14, 2011, 04:55:57 PM »
If you find a later model M20 flywheel ('89 or later IIRC) you won't need the starter since the teeth are the same as the M42.  I have an older model M20 single mass & starter if you're interested and local.  I'll bet it goes 40 pounds all up.  Shipping would be murder.
I think that the M42 or M40 non-A/C clutch might be a good deal for you too, if you can find one.  I'm pretty sure they were offered in Canada and you know it'll fit perfectly.  That's the only single-mass offered for the M42 in North America.  I'll post a link if I find one.
This is all I found so far:
http://www.318ti.org/forum/showthread.php?t=11586&page=2
I'll be looking for more.
« Last Edit: February 14, 2011, 05:02:40 PM by DesktopDave »
jakeb
« Reply #2 on: February 15, 2011, 06:49:33 AM »
Shipping actually isn't bad because you can fit the flywheel in a flat rate USPS box as well as the starter in another.  I shipped 3 m10 clutches with pressure plates in one $11 flat rate box.
« Reply #3 on: February 15, 2011, 07:54:42 PM »
That might work.  Let me know if you're interested, I can post some pics of the flywheel & pressure plate.
jakeb
« Reply #4 on: February 15, 2011, 08:35:38 PM »
send me a PM with price and any other info
thanks
redhead
« Reply #5 on: March 23, 2011, 05:43:00 PM »
I have an m20b25 flywheel & starter motor if you are still interested.
