Author Topic: what is this?  (Read 3315 times)
polkadot_boxerman
what is this?
« on: February 12, 2011, 12:09:58 PM »
monty23psk
  • -Receive: 17
what is this?
« Reply #1 on: February 12, 2011, 01:06:14 PM »
camshaft sensor
what is this?
« Reply #2 on: February 12, 2011, 03:00:44 PM »
Trigger contact is a really bad description at RealOEM.  It's also known as a CMP, cam position sensor or cam reference sensor depending on who you ask.
polkadot_boxerman
what is this?
« Reply #3 on: February 26, 2011, 09:58:31 PM »
I actually was looking at the wrong diagram. I think I'm leaking oil from number 11. Where the clip connects into the engine.
http://realoem.com/bmw/showparts.do?model=AF93&mospid=47305&btnr=11_4308&hg=11&fg=10
AcSchnitzer318is
what is this?
« Reply #4 on: February 27, 2011, 08:57:32 AM »
That's your crank position sensor and it doesn't enter the motor.  So you can't be leaking oil from there... if that is the CPS.
what is this?
« Reply #5 on: February 27, 2011, 09:21:02 AM »
Mine leaks from that vicinity too.  I'm pretty sure it's leaking from #3, the large timing plate gasket.  I've replaced all the easier stuff like the oil sender washer & dipstick o-rings, but the leak is still there.  It seems to ooze out the driver's side and then down onto the oil pan flange, finally dripping off the drain plug.
I'm just putting it off until I decide to do the whole timing chain case rebuild.  It'll need that sooner or later.
rjcaptsean
what is this?
« Reply #6 on: February 27, 2011, 11:39:19 AM »
When I had my balancer off, I had to polish the shaft as the Crankshaft seal had worn a slight groove in it.  I bet that is where your leak is.
polkadot_boxerman
what is this?
« Reply #7 on: March 03, 2011, 11:13:36 PM »
Just swap out my entire suspension. Took front subframe out to replace with 2.7 rack and went ahead and replaced upper and lower oil pan gaskets. No more leak :-D
