Author Topic: Requests For Writeups  (Read 74779 times)
MelbourneMike
« Reply #60 on: April 20, 2010, 07:29:26 PM »
Power steering delete please...(other than just cutting belt)  please elaborate Thanks!
Balleristic31
« Reply #61 on: September 14, 2010, 08:33:32 PM »
Coolant temp sensor replacement anyone?
ClassicSkril
« Reply #62 on: January 10, 2011, 02:08:26 PM »
how to replace power steering hoses on a 91 318is properly. I have a slow leak from the reservoir where the hoses connect at the base
Systema
« Reply #63 on: March 16, 2011, 04:55:36 PM »
Quote from: The Brown Bomber;41581
Looking for the BEST write up on changing my head gasket and any other work that would be best done at the same time.
Thank You in advance for your help and time.
Frank G.
Seconding this, if anyone knows where to find one.
e30itis
coil on plug install
« Reply #64 on: May 06, 2011, 10:01:25 PM »
every one says this is so easy did anyone do a write up on this install?
« Reply #65 on: May 07, 2011, 07:16:06 AM »
I did a COP conversion, didn't figure it needed a write-up.  Who's bracket do you have?
The only real trouble I had was getting it all to fit just right.  First I fitted the plate to the head (since I didn't have the correct "stand-off" shouldered studs).  One coil will have a mount ground off to fit the M42, that one has to go to #1 IIRC.
New NGK's, of course.  I'd strongly recommend a new gasket set for the cyl head cover as well, and a new cam sensor o-ring.
To complete the job I plugged the wiring harness into the coils first, then bolted the coils to the plate, then finally installed the whole deal in the car.
The only catch on this job would be firing order.  I've seen a lot of people try to plug the coils in to match firing order.  That's incorrect, the car will only run on two cylinders in that case.  Cylinder #1 (closest to the radiator) gets wiring connector #1.  Match the numbers & you'll be fine.
e30itis
« Reply #66 on: May 08, 2011, 07:52:31 PM »
i guess i am a novices novice....i bought the whole kit from Rob and em hq motorsport and i cannot find the install sheet that came with it and its not on their website i just thought it would be nice if someone had done a write up
« Reply #67 on: May 08, 2011, 09:02:19 PM »
Not that I've seen.  It'd be a good idea on a web site somewhere though, you're right about that.
16v of E30
« Reply #68 on: July 03, 2012, 10:22:59 PM »
idle control valve removal and cleaning please! sick of the stutters
Balkanac
« Reply #69 on: February 26, 2013, 10:35:49 PM »
How about the hydraulic lifters replacement guide? mine are getting really noisy
1991 BMW 318is E30 RED
noahcastle77
Re: Requests For Writeups
« Reply #70 on: March 19, 2016, 07:21:46 PM »
How about a write up for an alarm system install.  I've looked all over and I cant seem to make any sense of things.  I have a 318is e30.  Anything would help.  I located the central locking but was wondering where to hook up my wiring at? Pretty new at this but excited to get my e30 pimped out!
