Requests For Writeups
Author Topic: Requests For Writeups  (Read 74709 times)
bmuser
« Reply #45 on: August 27, 2007, 04:53:44 PM »
wow, so its not soldered in? thats really awesome that they left it like that.
lcgtrplr
request for a vacuum hose(under intake) bypass
« Reply #46 on: August 29, 2007, 07:43:37 PM »
I read on an earlier post that Clay D. eliminated the nest under the intake. I have a leak and have bought the multi-out hose and intake gasket but if i could get directions i would go that route. thanks
P. Kennedy
« Reply #47 on: August 29, 2007, 10:49:42 PM »
+15 on that.
Frank Gallegos
New to the e30 world and need help.
« Reply #48 on: January 23, 2008, 02:14:45 PM »
Looking for the BEST write up on changing my head gasket and any other work that would be best done at the same time.
Thank You in advance for your help and time.
Frank G.
gundy318
« Reply #49 on: February 23, 2008, 11:35:15 AM »
How bout a step by step guide for wiring and installing a lc-1?
DRtothE
DIY trani removal/driveshaft
« Reply #50 on: March 22, 2008, 10:25:35 AM »
Seems like nobody's doing any work/write-ups/DIY anymore, but i figured i'd ask for a step by step on removing the drive shaft and trani. im' having a major leaky problem on my wheels and if i could do this without having to remove the whole engine i'd appreciate it alot.
EdCrab!
« Reply #51 on: June 23, 2008, 01:11:48 AM »
Hey guys, I was browsing around looking for mods for the M42 engine when I came across this:
"Further, the long-stroke forged crankshaft from the M47 motor coupled with an overbore of +2 mm will make for a 2.1 L Stroker M42. The 86 mm pistons from a European 3.0 L S50 will produce a high compression, stroker M42 when coupled with the M47 crank. The addition of a MAF conversion from an M50 engine and properly setup cams, valvetrain, and tuning will yield potent output from the "lowly" M42."
So which M47 crank? Or has anyone heard anything about this?
Mhhh, more low end torque.. :D
JPSFAB
« Reply #52 on: July 11, 2008, 09:09:02 AM »
I've heard of converting to coil on coil ignition. Is that possible on a 91 318is m42 motor.
kenika65
« Reply #53 on: July 11, 2008, 09:14:54 AM »
Yes and you need to search it is everywhere.
Rafiki
« Reply #54 on: February 20, 2009, 07:01:01 PM »
fuel pump!
dinu.negrean
« Reply #55 on: June 18, 2009, 01:50:37 AM »
if anyone is still on, i would like to know if there is a DIY about injectors swap. thanks!
M42_Jester
101 Performance Projects
« Reply #56 on: June 19, 2009, 07:57:04 AM »
Has anyone heard of the book "101 Performance Projects for you BMW 3 Series 1982-2000" ?
there are some great write-ups in there about nearly everything to do with your engine, electrical systems, brakes, wheels, interior, exterior, you name it, they got something on it.
check it out...it's worth it...
http://www.101projects.com/BMW/index.htm
« Reply #57 on: June 19, 2009, 08:18:28 AM »
I wanted a step-by step for sunroof replacement, but I ended up just doing it.  I'll post some pics.
I have heard about Pelican Parts' 101 Projects.  I was going to add it to my A/C refurb parts when I got the chance.  Looks pretty in-depth with a wide variety of topics, and it averages about three pages per topic.
Still...if replacing a head gasket is "for the adventurous" my life is loaded with excitement...
« Last Edit: June 19, 2009, 08:23:36 AM by DesktopDave »
keflaman
  • -Receive: 35
Another Way To Locate Vacuum Leaks
« Reply #58 on: June 22, 2009, 03:03:07 PM »
After rebuilding the head on my friend’s Miata, I was extremely disappointed when the car started right up, but wouldn’t idle or run below a few thousand RPMs. It certainly indicated a vacuum leak, but where?
Boy, at times like this it sure would be nice to own a smoke detector, but have you seen how much they cost?
After a few searches and viewing some video clips http://www.youtube.com/watch?v=-V_W_SFxYoI&feature=related, I decided to explore the basic premise behind a smoke detector by using common tools, soapy water, a garden pressure sprayer, a leak down tester and...a little Yankee ingenuity. No offense to those living below the Mason/Dixon Line.;)
Before you read any farther realize you will be using pressurized air which may present personal hazards if you don't do it correctly. Wear eye protection and never, never run with scissors:eek:.
You get my point, right?
First order of business was to isolate the intake manifold so I could pressurize it. I removed the throttle body and capped off the intake with a latex glove and some tape. Then I installed my leak down tester to one of the cylinders and set the cams up so the intake valves were open and exhaust valves were closed. I checked the other cylinder’s valves to ensure they weren’t in a position to allow air to escape into the exhaust system.
http://www.m42club.com/forums/album.php?albumid=67&pictureid=366
Next, I slowly applied air pressure to the leak down tester. At 25psi the latex glove was fully inflated and I could hear air escaping, but couldn’t see where. Using a mixture of dishwashing soap and water in a garden pressure sprayer http://www.m42club.com/forums/album.php?albumid=67&pictureid=369, I started from the top and sprayed the surfaces where the intake manifold mated to the cylinder head. This picture shows how easy you can get into small areas with pinpoint precision. Here I am about to spray around the fuel injectors to see if a seal was damaged during the installation. http://www.m42club.com/forums/picture.php?albumid=67&pictureid=367
For reference, here’s what you will see when the soap is applied to an area where air is leaking out http://www.m42club.com/forums/album.php?albumid=67&pictureid=368; Hint: The bigger the leak, the bigger the bubbles. A very slight pinhole may take longer to show up and it will have a frothy appearance.
In this particular case I found I had installed the intake gasket from an NA (First Generation) Miata vice an NB. After changing out gaskets I set everything up again and I barely got to 3 psi before the glove blew off like on over-inflated balloon!
So in summary this method may be a bit crude and it wasn't on an M42, however, there are a few advantages to doing it this way vs. spraying a hot, running engine down with flammable aerosol liquids while listening to a change in engine rpms. I don't know about you, but even when my car is running right the rpms fluctuate just a bit:D
BlueBMW
« Reply #59 on: December 24, 2009, 03:33:10 PM »
I'll have to try your method next time I need to find a leak at home.  We get spoiled working at the dealership with a smoke machine.  That thing is absolutely amazing for finding intake and fuel system leaks.
