Author Topic: Requests For Writeups  (Read 74687 times)
kowalski
  • El\' Duder
« Reply #15 on: April 10, 2006, 06:26:44 PM »
if its a daily driver i would recomend getting a spare valve cover and intake (if you have access to cheap ones) and get them beadblasted and powdercoated, it will look good forever.
you can also use base clear (car paint) which is good for hi temps as well.
Sale:
Fore Sale Thread
shellback
« Reply #16 on: April 11, 2006, 11:31:44 AM »
Quote from: christophbmw
They are really easy actually W/ the right tools (use a very long 3 foot exstension W/ a swivel socket & a breaker bar attached to the end, they should pop right out). I'll be doing a clutch soon but not untill summer, and Id be more than happy to do a write-up.
I did have the tranny off in october and i replaced the torx W/ some nice zinc coated 17mm bolts all around (i hate damn torx, they are cheesy and the only reason they where put on is so the DIY person couldnt take them off).
Great info - thanks.
Now I need to find a 36" extension! I checked Sears but only go up to 24" :mad:
Thanks again,
Chris
kowalski
  • El\' Duder
« Reply #17 on: April 11, 2006, 01:00:15 PM »
just double up extensions, i do it all the time.
Sale:
Fore Sale Thread
thumper3ld
  • fathead ***
Motor Mount replacement.
« Reply #18 on: April 12, 2006, 09:23:44 PM »
Anyone got a write up for replacing motor mounts and possibly removing and replacing the cross member the motor mounts are attached to??
Thanks.
Zoso
« Reply #19 on: April 13, 2006, 11:44:10 AM »
Quote from: thumper3ld
Thanks.
Ouch - Is yours mangled?
At least they're under $100 to replace.
thumper3ld
  • fathead ***
« Reply #20 on: April 13, 2006, 12:07:51 PM »
Nah, mine is cracked. You wouldnt happen to have a part number?
« Reply #21 on: April 13, 2006, 02:16:31 PM »
Thanks.
Here is Pelican's write up on motor mount replacement LINK I'd also look into replacing the tranny mounts depending on what condition they're in.
Have you decided which type mounts you're putting in?
Febi Guibo
  • m42 reporter
« Reply #22 on: April 13, 2006, 02:25:21 PM »
Quote from: Eurospec
hey man, you mind starting a thread with this link in HOW-TO?
(I added it to the quick reference... THANKS for this!)
Support M42club.com !!
thumper3ld
  • fathead ***
« Reply #23 on: April 13, 2006, 03:30:27 PM »
Yeah, I ordered the e21 mounts that kowalski suggested.
« Reply #24 on: April 13, 2006, 03:57:05 PM »
Let us know how that goes.
« Reply #25 on: April 13, 2006, 04:04:32 PM »
Quote from: Febi Guibo
You got it boss :)
Zoso
« Reply #26 on: September 01, 2006, 01:37:02 PM »
Request:
Timing Chain/Timing Chain Rail Guide replacement.
(I know of this one http://www.esatclear.ie/~bpurcell/318istimingchain.html , but more is always better.
$.02 worth.
« Reply #27 on: September 01, 2006, 03:09:28 PM »
When it comes to putting transmissions back in, what really helps is putting studs in a couple of the transmission bolt holes. Put them in finger tight. They support the weight of the transmission while you do the line it up wiggle. I'll have a write up in the next month or so on M3 sway bar links. Also on an unauthorized and highly unapproved mod incorporating the latest in homemade metallurgy.
« Last Edit: September 01, 2006, 03:18:06 PM by D. Clay »
FL318is
Question.
« Reply #28 on: September 01, 2006, 03:11:32 PM »
Are write ups the same as DIY?
I would like to see the following write ups and/or DIY
1)  Race seat install
2)  IPOD install
3)  Headlight conversion
4)  Timing case including chain replacement
5)  Performance installs of any kind
6)  Exterior mods
7)  Clutch
8)  Fluid changes
For all write ups I personally would like to see a basic format.  For example include parts lists, tool list, time estimates and a skill level.  Particularly the write up should include any and all problem areas and photos.
JetBlack95
« Reply #29 on: September 22, 2006, 02:45:40 PM »
can i get a write up for changing the belt tensioner, i have the M42 with the Serp belt ( E36 ) and i want to swap it while replacing my belts, just for good preventive main.  anything you have would be awesome...
thanks!
and how about a compressor replacement?
