A continuation from:
http://www.m42club.com/forums/showthread.php?t=12624So now I have a spare long block that needs a couple parts, but is in good shape, and some other parts that can help me do this, as well as a place to work. I decided to get it towed back to marin and get to work.
Well today I found some interesting if not good results from the teardown.
I pulled the Plugs today and cranked the engine over by hand as advised to by a family friend mechanic. and felt for any resistance or seizure. luckily, I found niether, and the engine turned over extremely smooth. this points me to think that there was no contact between the valves and the pistons.
Secondy, Looking at the plugs, there was no shrapnel damage, or any for that matter on the spark plugs. This also points me to believe that the pistons and valves never touched.
when taking a mini LED flashlight and poking around the combustion chamber through the spark plug areas I didnt see any damage on the pistons, jsut a we bit of carbon coating.
im about to start pulling off the timing cover gasket to see what rails are damaged ETc..... Anyone have anything else they think I should look out for?
