Author Topic: M3 3.2 6speed gearbox to an M42  (Read 10304 times)
E36-italia
  • -Receive: 6
    • Motorsport-Media-Design.com
« on: October 26, 2010, 09:10:10 AM »
I think that I have to replace my clutch in the near future (halfway the stroke it engages, but without any feel)
but the otherday i found somebody who sells rebuilded bmw engines/gearboxxes..
He also has some M3 gearboxes in stock...
The M3 3.2 6speed is, includind 1 extra gear, a fraction shorter...which should improve acceleration
here's a ratio comparison
M3:
1 - 4.23
2 - 2.51
3 - 1.67
4 - 1.23
5 - 1.00
6 - 0.83
weight = ??
here for the M42:
1 - 3.72
2 - 2.02
3 - 1.32
4 - 1.00
5 - 0.81
Weight = ??
Not totally sure about the ratios, could not find official bmw info yet..
A shorter gearbox (and with 1 gear more) would be handy, since I live at the foot of the italian alps ;-)
now i you might guess my question... would a M3 gearbox fit to an M42?
romkasponka
« Reply #1 on: October 26, 2010, 09:58:32 AM »
Good idea, except first gear ratio :). It could be that you will need shorter drive shaft.
E30 318is M42
E36 318is M44
fabe
« Reply #2 on: October 26, 2010, 10:44:08 AM »
the gearbox will fit... just that u'll need to find the right lenght of the drive shaft to mate with the longer 6 speed gearbox..
e30boarder
« Reply #3 on: October 26, 2010, 11:49:21 AM »
is there any other bmw 6 speed trannies that can bolt up to the m42? or is that the only one
romkasponka
« Reply #4 on: October 26, 2010, 12:30:41 PM »
Quote from: e30boarder;97968
6 speed gearbox was fitted not only to m3 E36...
E30 318is M42
E36 318is M44
e30boarder
« Reply #5 on: October 26, 2010, 02:21:00 PM »
i realize that.. just wondering if there were more that could easily be adapted to work with the m42
fabe
« Reply #6 on: October 26, 2010, 09:58:44 PM »
The M42 has the same gearbox bellhousing bolt pattern with the M5x and S5x inlie 6 engines.. So it's compatible with a lot of gearboxes... only issue is sourcing the right length of the short shaft... unless you're adventurous enuf to cut and reweld the shaft to the required length..
E36-italia
  • -Receive: 6
« Reply #7 on: October 27, 2010, 02:39:21 AM »
Quote from: fabe;97991
judging from your words...an M3 driveshaft won't fit?
Cut&weld a driveshaft isn't really dangerous with a 140bhp engine... I don't want to do that with a 300bhp engine thou...
nicknikolovski
« Reply #8 on: October 27, 2010, 03:53:52 AM »
I'd get a custom driveshaft made up.
e30boarder
« Reply #9 on: October 27, 2010, 10:34:16 AM »
ill have to look into that. i would love to have a 6 speed in my e30
supadave
« Reply #10 on: October 27, 2010, 01:52:50 PM »
has anybody done this?
« Reply #11 on: October 27, 2010, 06:25:46 PM »
I've seen a few. Mostly using 330i E46 transmissions though, iirc
supadave
« Reply #12 on: October 29, 2010, 07:12:51 AM »
More info please! A link or something
fabe
« Reply #13 on: October 29, 2010, 09:30:11 AM »
The only thing is to source for the right length drive shaft.. Maybe the shorter shaft from the E30 M20 can be used..
Length of the shifter link and the shifter holder can be modified without much hassle.
I guess for a start, measurements of the stock G240 gearbox and driveshaft (the front portion) would be good.
KenC
« Reply #14 on: October 29, 2010, 10:11:00 AM »
What do the e46 6speeds usually go fo?
I think the 1st gear ratio would pose some problems with my 4.45LSD haha
