Author Topic: M3 3.2 6speed gearbox to an M42  (Read 10308 times)
E36-italia
  • -Receive: 6
    • Motorsport-Media-Design.com
« Reply #15 on: October 29, 2010, 10:21:53 AM »
Quote from: fabe;97991
unless you're adventurous enuf to cut and reweld the shaft to the required length..
Spoke to a guy who prepared a fair few WRC/group A/historic race and rally cars.. he said that cut and weld a shaft is perfectly feasable... people who build custom trucks/semi trailers are quite ok.
he did it with 3 cars, one did the london sydney marathon back in '93
and after that: cape to cape... clocked up a fair few miles... never had a problem
(Rover P5B with a 3,5L V8 ~ 250/300 BHP)
E36-italia
  • -Receive: 6
« Reply #16 on: October 29, 2010, 10:24:48 AM »
Quote from: KenCopperwheat;98107
What do the e46 6speeds usually go fo?
I found a E46 SMG box for 600 EUR...but it is stuck in some gear, not sure about the fix.. a sequential gearbox would be cool imo (a bit overdone in a 16year old E36)
fabe
« Reply #17 on: October 29, 2010, 06:29:00 PM »
Quote from: E36-italia;98108
of cos it's feasible, when our stock shaft is welded together. just that u need to specialist to get it done proper with balancing. If the shaft is off balance, it's very irritating to drive.. Minor one would be slight vibration during take off.
nicknikolovski
« Reply #18 on: October 29, 2010, 09:49:42 PM »
Quote from: E36-italia;98109
Don't get a SMG gearbox - too problematic. Trust me. and every part too expensive.
romkasponka
« Reply #19 on: October 30, 2010, 03:37:09 AM »
Better option is this http://www.samsonasmotorsport.com/index.php?-484491559 ;)
One day I will buy one for my car...
E30 318is M42
E36 318is M44
dvmotorsports
« Reply #20 on: October 30, 2010, 03:49:34 AM »
When i worked for the dealer and we would get SMG trans stuck in a gear, it was always a bad SMG pump or module failure. Which results in replacement and programming of either unit.
supadave
« Reply #21 on: November 01, 2010, 08:10:04 AM »
Quote from: romkasponka;98131
How much?
ziedas nr 1
« Reply #22 on: November 01, 2010, 10:22:07 AM »
araund 4000-5000 euros.
ziedas nr 1
« Reply #23 on: November 01, 2010, 10:31:26 AM »
Quote from: E36-italia;97960
I think that I have to replace my clutch in the near future (halfway the stroke it engages, but without any feel)
but the otherday i found somebody who sells rebuilded bmw engines/gearboxxes..
He also has some M3 gearboxes in stock...
The M3 3.2 6speed is, includind 1 extra gear, a fraction shorter...which should improve acceleration
here's a ratio comparison
M3:
1 - 4.23
2 - 2.51
3 - 1.67
4 - 1.23
5 - 1.00
6 - 0.83
weight = ??
here for the M42:
1 - 3.72
2 - 2.02
3 - 1.32
4 - 1.00
5 - 0.81
Weight = ??
Not totally sure about the ratios, could not find official bmw info yet..
A shorter gearbox (and with 1 gear more) would be handy, since I live at the foot of the italian alps ;-)
now i you might guess my question... would a M3 gearbox fit to an M42?
gearbox is fit.you need to replace a driveschaft,modified a shortschift. abaut weights, a m42 gearbox weight 29kg and 400g. a m3 3,2 6speed gearbox weight 46kg.
supadave
« Reply #24 on: November 11, 2010, 10:06:22 AM »
Quote from: ziedas nr 1;98185
WOW! Thats crazy.
supadave
« Reply #25 on: November 11, 2010, 10:07:39 AM »
I would like to see some documentation on a six speed swap.
