Author Topic: My new build thread  (Read 9946 times)
gtatbrissy
My new build thread
« on: October 23, 2010, 11:38:40 PM »
Ok so some of you may remember my car and other thread about ITBs. Well things have changed since then. After my itb project stalled i started to wonder weather i should continue mondify the m42 or purchase something with more potential and something that was a bit my common in the race world. After doing some research i decided on the s14 m3 motor. so the search began for a suitable engine. needless to say i found this.
its a 2.5l bmw e30 m3 sport evo motor. it has a set of big cams, carbon intake and alpha n piggyback ecu.
because the engine wont be in the car until next year, this gives me time to sort our alot of small jobs. like new seat, suspenion bushes, sway bars, roll cage, etc.
i already have my seat which is a omp grip which is getting on wednesday
i also pulled my dash out and got rid of my a/c, heater, blower fans, radio and tidy up the wiring.
this is the end result, i plan to make up a switch board when the new motor goes in
so alot of changes are happening and i will be updating this thread as soon as something arrives. next event is mt cotton hillclimb in brisbane on the 30th so if anyone is going out there please come and say hi
P Zero
My new build thread
« Reply #1 on: October 27, 2010, 12:09:33 PM »
Looks good. Liking the S14 :D
But does he get to stay without an M42? :p
BMW E30 318is track project
Audi A4 130 Sport Avant
deekay
My new build thread
« Reply #2 on: October 27, 2010, 02:10:26 PM »
yowza.
mind if i ask what the S14 cost?
gtatbrissy
My new build thread
« Reply #3 on: October 28, 2010, 04:07:51 AM »
the s14 was 7k.... thats with dogleg close ratio gearbox, driveshaft, clutch, flywheel and shipping from usa to australia.
bit of an update got my seat installed by rx automotive who made custom side mounts
gtatbrissy
My new build thread
« Reply #4 on: November 30, 2010, 06:00:47 AM »
Update!!!!
got new rear springs because i thought it sat a bit to high. Also selling off the motor before christmas which should give me money for front suspension uprade, new subframe and roll cage.
Before
New vs old
After
longms
My new build thread
« Reply #5 on: December 01, 2010, 10:38:30 AM »
How much power are you putting down with that motor? Would a regular s14 go right into an E30 or was there a lot of modifications?
Warsteiner
  • -Receive: 21
My new build thread
« Reply #6 on: December 01, 2010, 11:59:50 AM »
The S14 fits in the 318,325 the same as an M3 since they are all E30's.
The stock Sport Evo motor put out 238HP at the crank. With A-N and tuning anything is possible.
Cheers,
~Ralph
gtatbrissy
My new build thread
« Reply #7 on: December 02, 2010, 04:05:46 AM »
Yer they bolt straight in same sub frame. This motor puts out around 210rwhp, so about 260 at the flywheel.
Warsteiner
  • -Receive: 21
My new build thread
« Reply #8 on: December 02, 2010, 07:56:27 AM »
Hey gtatbrissy, Nice job on the score of the Sport Evo motor.  BMW's usually have a drivetrain loss of about 17%. So if you take your 210 x .17 =246. Close:-)
this is what E36M3's are making on the dynojet dynos at the rear wheels (205-207) and that puts them right around the 240HP mark that they are advertised at.
If you ever decide to rebuild it think about changing the compression and tuning and you should see a nice increase in power. That motor stock only has 10.2:1 compression....11.5 would be a world of difference. Then you're in the 300+ crowd if you do the right set of cams.
Good Luck with the install....
Cheers,
~Ralph
gtatbrissy
My new build thread
« Reply #9 on: December 02, 2010, 08:11:17 AM »
Thanks mate. It already has a set of cams, it made 260hp on an engine dyno I was just estimating a rwhp figure. I do want 300 hp eventually lol
Warsteiner
  • -Receive: 21
My new build thread
« Reply #10 on: December 02, 2010, 08:15:52 PM »
Ok kool on the cams. I'm sure that you have a set of Schricks in there? Prob 284/276..... There are definitely more aggressive cams to move up in power but that also moves your power band up too. If it's a street car then I would stay where you're at but for a track car there are a lot of different options. That also depends on if you'll change out the pistons for higher compression and deeper reliefs as to not have an interference issue.
Good luck with everything...
Cheers,
~Ralph
gtatbrissy
My new build thread
« Reply #11 on: December 03, 2010, 01:51:08 AM »
It is a race car. I plan to keep it the way it is for now until i get bored lol then i will proberly get more aggressive cams, light weight piston etc.
Thanks for your advice Warsteiner as I still need to learn alot about these motors lol im still a newby.
regards
glenn
gtatbrissy
My new build thread
« Reply #12 on: December 20, 2010, 04:12:02 AM »
some parts started arriving today. i am also shipping with a different company now because the previous on did fuck all in 2 months.
as the pictures tells i got new control arm bushes, engine and gearbox mounts and longer wheel studs for a big brake upgrade next year.i bought these from ireland engineering who are a great company to deal with and i highly recommend them. i am also getting a new front subframe so i will fit the control arm bushes when i get that. also ordered momo mod 07 steering wheel.
apart from that it has been pretty quite, should pick up pace after xmas
gtatbrissy
My new build thread
« Reply #13 on: December 20, 2010, 05:43:42 AM »
also got some pics of my front coilovers
