Author Topic: disabling power steering  (Read 2879 times)
bryan@cedainc.net
« on: October 17, 2010, 07:59:28 PM »
PS pump is shot so I removed the belt. Steering is tight but manageable & preferable for autocrossing. I really don't need it & could stand to lose some weight (the car, not me). Should i remove entire PS system...pump, resevoir, plug hoses, etc? Any issues, problems deleting this system? Thanks
KY Colonel
« Reply #1 on: October 17, 2010, 09:48:49 PM »
I've removed the belt on mine too.  No problems, unless you mind a little upper-body workout whilst parallel parking.
I made sure to drain the rack so I wasn't pushing fluid around.  I'll get to pulling the rest of the P/S system one of these days.
There was a member with some nice alu blanking plate for the steering rack fitting.  That'd be nice.
1991 E30 M42
« Reply #2 on: October 18, 2010, 11:44:16 AM »
I removed everything including the the bits inside the rack and it seem to lighten up the steering effort as opposed to just removing the belt
http://www.flyinmiata.com/tech/depower.php?x=1
iamcreepingdeath
« Reply #3 on: October 25, 2010, 06:48:53 PM »
yep, remove it all.  drain the rack and plug it to keep dirt/water out.  You can lose like 15-20 lbs and with no fluid steering will be easier.
« Reply #4 on: October 25, 2010, 07:05:10 PM »
Peer pressure DEMANDS IT!!
