Turbo suggestions
Author Topic: Turbo suggestions  (Read 8668 times)
chips
    • http://www.drakedesign.co.uk
Turbo suggestions
« on: October 17, 2010, 06:31:38 AM »
I've just about finished my M42 conversion into a 316 shell. It should be on the road in the next couple of weeks. Obviously I'll be quite bored with no spannering to do so I've started researching turbos.
I'm going to be keeping it low-budget, so I'm going to me using the chopped up M50 turbo ebay manifold and a second hand turbo. However I will be running MS and will be aiming for at least 250bhp on stock mechanicals.
Everyone who has turbo'd the M42 has used a different turbo so I'm not sure what the best route to take is? Turbo options I've considered so far are;
VW 1.8t
Mitsi Evo
Volvo?
Scooby
Those are the most popular turbo applications over here I suppose. Does anyone have any suggestions as to what would be about right for the M42?
Heres a quick photo of the car :)
« Last Edit: October 17, 2010, 06:34:23 AM by chips »
carlos318is
Turbo suggestions
« Reply #1 on: October 17, 2010, 07:55:59 AM »
Hi mate I will be watching with intrest as I am also from the UK and there is not much info about
clutchkick
Turbo suggestions
« Reply #2 on: October 17, 2010, 02:22:35 PM »
gt28 or gt25 variants from the nissan sr20det engine.
Im running a gt2864
chips
Turbo suggestions
« Reply #3 on: October 17, 2010, 02:45:29 PM »
Quote from: clutchkick;97593
Im running a gt2864
Thanks mate. How much boost are you running at?
clutchkick
Turbo suggestions
« Reply #4 on: October 17, 2010, 03:01:55 PM »
currently 0 because i had to build a new motor. but im shooting for about 15-18 psi.
should yield 275-300 crank hp with a standalone tune
deekay
Turbo suggestions
« Reply #5 on: October 17, 2010, 03:06:04 PM »
on a budget, a turbo from an M21 diesel (we only got those in the 5-series... may also be in the 3er over there?) is the same spec as a volvo one; T3 .42/.48AR i think? should be good for a wide powerband on an M42.
chips
Turbo suggestions
« Reply #6 on: October 17, 2010, 03:31:35 PM »
Quote from: deekay;97596
I was hoping to run somewhere around 10 - 12psi (0.7 - 0.8 bar). So this size of turbo is probably too small.
I think we did get the M21 engine though, in the E30 as well as the E28.
bar73k
Turbo suggestions
« Reply #7 on: October 17, 2010, 04:14:03 PM »
Previously I was running a GT2871R, on 20~22psi the car made 213kw at the wheels, quite a nice turbo that was, I would recommend it
I’m upgrading now to a GT3076R
chips
Turbo suggestions
« Reply #8 on: October 17, 2010, 04:16:28 PM »
Quote from: bar73k;97599
I assume you have upgraded the internals?
deekay
Turbo suggestions
« Reply #9 on: October 17, 2010, 05:49:28 PM »
Quote from: chips;97597
the ARs may look small, but it's still a 50-trim compressor-
run the numbers for yourself if you like, the t3 50-trim is the 3rd map:
http://www.turbofast.com.au/turbomap.html
(i wouldn't have suggested it unless i'd already looked into it myself ;))
bar73k
Turbo suggestions
« Reply #10 on: October 18, 2010, 02:30:49 AM »
Quote from: chips;97600
yeh i have custom forged JE pistons, comp ratio 8.0:1
i have Hbeam rods in there now too, but for what you are looking at you dont need rods, the standard ones are fine, they are quite good
P Zero
Turbo suggestions
« Reply #11 on: October 19, 2010, 06:53:17 AM »
Thanks deekay. I still haven't had a chance to have a proper play with that calculator but it looks very useful.
Like clutchkick said, I've been looking at Garrett T28 turbo's off SR20DET engines and the like. It looks like this one has an AR of 60.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=200529737322&ssPageName=STRK:MEWAX:IT
« Last Edit: October 19, 2010, 07:05:18 AM by P Zero »
BMW E30 318is track project
Audi A4 130 Sport Avant
clutchkick
Turbo suggestions
« Reply #12 on: October 19, 2010, 07:22:14 PM »
when funds allow I would really like to upgrade to this new turbo that just came out. Its really an awesome compressor
P Zero
Turbo suggestions
« Reply #13 on: October 21, 2010, 01:30:04 AM »
Quote from: clutchkick;97697
What are those wheels on your car by the way?
bmwconnect
Turbo suggestions
« Reply #14 on: October 21, 2010, 04:04:29 PM »
Grab a T3/T4 hybrid off ebay and rebuild with garret seals ... Mine has lasted two years with no problem
Midnight YouTube Channel
