Author Topic: Turbo suggestions  (Read 8661 times)
chips
    • http://www.drakedesign.co.uk
Turbo suggestions
« Reply #15 on: October 21, 2010, 04:15:56 PM »
Quote from: bmwconnect;97774
Grab a T3/T4 hybrid off ebay and rebuild with garret seals ... Mine has lasted two years with no problem
I like that idea, after checking some prices. I assume it's not a garrett manufactured turbo, just a pattern part?
Can you tell me some more about your car? Stock motor, how much boost, management, etc...
bmwconnect
Turbo suggestions
« Reply #16 on: October 21, 2010, 06:02:39 PM »
places like this can hook you up :)
http://www.gpopshop.com/garrettt3kits.html
mysetup is e36 M42 240xxxKms, Stock internals(accept for head bolts...switched to metric blue) 15psi daily , 60Lb injectors, stock Motronic chip tuned by Midnight Tuning
http://www.midnight-tuning.com Under Construction
Midnight YouTube Channel
superpotter80
Turbo suggestions
« Reply #17 on: November 07, 2010, 09:39:52 AM »
Quote from: chips;97577
I've just about finished my M42 conversion into a 316 shell. It should be on the road in the next couple of weeks. Obviously I'll be quite bored with no spannering to do so I've started researching turbos.
I'm going to be keeping it low-budget, so I'm going to me using the chopped up M50 turbo ebay manifold and a second hand turbo. However I will be running MS and will be aiming for at least 250bhp on stock mechanicals.
Everyone who has turbo'd the M42 has used a different turbo so I'm not sure what the best route to take is? Turbo options I've considered so far are;
VW 1.8t
Mitsi Evo
Volvo?
Scooby
Those are the most popular turbo applications over here I suppose. Does anyone have any suggestions as to what would be about right for the M42?
Heres a quick photo of the car :)
i used td05h 16g scooby and its spot on next to no lag,and pulls all the way to redline,check out my pics
[SIGPIC]
Aus-m42turbo
Turbo suggestions
« Reply #18 on: November 15, 2010, 03:20:52 AM »
Clutchkick; How do you find the T28? Can you give a quick description of when boost starts to build, and when peak boost is reached. (After its run). And also what are those wheels?
jintermont
Turbo suggestions
« Reply #19 on: November 28, 2010, 02:17:26 AM »
