Author Topic: Jectron and Ventil  (Read 4968 times)
FL318is
Jectron and Ventil
« on: September 18, 2006, 08:48:02 AM »
Lubro Moly in my car.  Good idea or bad idea?  I was going to try it.  Before I do I was hoping to get input from the board.  Remember, I break stuff! :D
Euro Nation
Jectron and Ventil
« Reply #1 on: September 18, 2006, 09:48:00 AM »
Good products. I've used them in a lot of stuff. Particularly Diesel Purge.
-Aaron
\'91 318i - Dead and gone
http://www.euronationvw.com
I own VWs... lots of them.
Jectron and Ventil
« Reply #2 on: September 18, 2006, 09:56:41 AM »
Are these additives?
FL318is
Yes they are.
« Reply #3 on: September 18, 2006, 10:17:58 AM »
Quote from: bmwman91
Heres a link.
http://www.gprparts.com/brands/lubroMoly/
Jectron and Ventil
« Reply #4 on: September 18, 2006, 11:58:17 AM »
So do you run a can of Jectron in one tank, then hit up some Ventil Sauber on the next?
FL318is
Looks like it.
« Reply #5 on: September 18, 2006, 12:59:13 PM »
According to what I read.  I was going to wait until I have a half tank gone and top it off for good mix.
Jectron and Ventil
« Reply #6 on: September 18, 2006, 01:52:21 PM »
Although I haven't used LM products myself, I've generally heard good things about them. Since we're on this topic... I was planning to use a bottle of BG44K which according to BG's website, "Safely, rapidly and thoroughly removes engine deposits in combustion chambers, intake manifolds, ports and on valves. It restores flow in fuel injectors and cleans the entire fuel system". It does what Jectron and Ventil Sauber do in one bottle/treatment.
FL318is
Cool!
« Reply #7 on: September 18, 2006, 02:05:10 PM »
I don't have much engine history so I was hoping to clean it up abit.
Jectron and Ventil
« Reply #8 on: September 19, 2006, 08:23:35 PM »
Quote from: FL318is
Be sure to update us on how it turns out. Depending on the mileage, type of gas you pump, and any previous treatments, you may notice a difference.
FL318is
Roger That!
« Reply #9 on: September 20, 2006, 08:41:45 AM »
Quote from: Eurospec
Planned for this weekend.  One of the A&Ps here said to wait until the tank is low, pour it in, run it close to empty and then top off.  I think I will mix it into half a tank then top off.
M42boy
Jectron and Ventil
« Reply #10 on: September 20, 2006, 09:13:40 AM »
Quote from: FL318is
I use Ventil Sauber all the time!  Good stuff.  :D
Jectron and Ventil
« Reply #11 on: September 20, 2006, 01:03:39 PM »
FL, you might consider replacing the fuel filter if it looks old or hasn't been replaced lately. Not sure if this needs to be done before or after the application. I'm thinking before.
Jorgeconrico
Jectron and Ventil
« Reply #12 on: September 18, 2009, 07:49:49 PM »
This thread is ancient, but I was wondering if anyone else has used Jectron and Ventil Sauber.
JP 91iS
Jectron and Ventil
« Reply #13 on: September 22, 2009, 11:14:56 PM »
I just started using them last month. So far nothing bad has happened, that's about all I can say. I don't get out to drive much more than city traffic lately and the city traffic here is fucking. horrible. I bought a bunch of the stuff in a kit from bavauto along with the engine clean and engine protect.  Don't know how well its working but it makes me feel good at least.
-JP
Project M42: generating funds
1991 E30 M42
Jectron and Ventil
« Reply #14 on: September 23, 2009, 01:14:22 AM »
i tend to stay away to additives, I have seen what that shit does to cars and had to fix them because of it while I worked at the dealership. You get an engine with deposits or sludge buildup and put any kind of oil treatment in it, goodbye engine hello junkyard. Same goes with automatic transmissions, but those can be worse. If you have never changed your fluid (say you have 80000 miles on the original) then you put new fluid in, it will brake up all the deposits and ruin your tranny.
