Author Topic: Bl0mgren - 318is E30 Turbo  (Read 35842 times)
Bl0mgren
« Reply #75 on: May 05, 2011, 10:31:10 AM »
dynoed to 194hk and 288nm. It's running very lean under boost pressure so it have more to give with bigger injectors!
Rain_E30
« Reply #76 on: May 05, 2011, 01:59:29 PM »
Gets better and better. :)
Could you make an onboard Video of your car once on asphalt roads?
Im interested how the engine now sounds, with your Turbocharger.
1990 318is E30
Bl0mgren
« Reply #77 on: May 19, 2011, 10:22:46 AM »
New rims and fuel injectors.  60 lbs/hr @ 43.5 psi
romkasponka
« Reply #78 on: May 20, 2011, 03:10:31 AM »
Looks expensive ;)
What is rims size?
E30 318is M42
E36 318is M44
Bl0mgren
« Reply #79 on: May 20, 2011, 04:54:40 PM »
8x17" 205/40 tires
« Reply #80 on: May 21, 2011, 12:00:47 AM »
Doin it RIGHT!
Bl0mgren
« Reply #81 on: July 02, 2011, 06:23:40 PM »
:rolleyes:
Bl0mgren
« Reply #82 on: July 04, 2011, 05:01:57 PM »
Spacers and new Spal cooling fan :)
Bl0mgren
« Reply #83 on: July 05, 2011, 02:21:29 PM »
brakes
romkasponka
« Reply #84 on: July 06, 2011, 03:47:35 PM »
Are they from BMW E38?
E30 318is M42
E36 318is M44
Bl0mgren
« Reply #85 on: July 06, 2011, 05:26:17 PM »
brembo 4-pot e38 and 312mm disc. Works great :D
romkasponka
« Reply #86 on: July 07, 2011, 03:49:40 AM »
Quote from: Bl0mgren;105135
Are discs BMW E36 M3?
E30 318is M42
E36 318is M44
Bl0mgren
« Reply #87 on: July 07, 2011, 12:03:12 PM »
Quote from: romkasponka;105144
re-drilled audi/vw
Bl0mgren
« Reply #88 on: July 14, 2011, 02:39:55 PM »
Diff 188 3.73! Better gearing :)
Bl0mgren
« Reply #89 on: July 21, 2011, 05:12:35 PM »
changed to custom e85 turbo chip and 15 psi boost :D
