Bl0mgren - 318is E30 Turbo
Author Topic: Bl0mgren - 318is E30 Turbo  (Read 35763 times)
Bl0mgren
« Reply #45 on: January 08, 2011, 03:46:33 PM »
2.5" exhaust
bad clearance
need rewelding.. :mad:
NisseJärnet
« Reply #46 on: January 08, 2011, 04:25:10 PM »
Drygt :( Vill du göra det lätt ta en 90 graders aluböj eller nåt bara och skarva slangen med :)
-88 E30 325i M50 6spd turbo, 764whp
-89 E30 318i M42, 140hp COP conv. (E36 engine + gearbox, 3.73 188 diff)
-90 E30 318is M42 turbo, 240whp (sold)
http://www.youtube.com/nissejarnet
JulianS
« Reply #47 on: January 20, 2011, 02:58:29 AM »
Fräscht :) vart håller du hus då blomgren?
romkasponka
« Reply #48 on: January 20, 2011, 03:38:55 AM »
As I know drain should above oil level in the sump.
E30 318is M42
E36 318is M44
Bl0mgren
« Reply #49 on: January 20, 2011, 12:51:35 PM »
Quote from: JulianS;100704
karlstad ;)
Quote from: romkasponka;100708
yeah.. but have worked for other this way :)
update..
Bl0mgren
« Reply #50 on: January 23, 2011, 05:00:04 PM »
Up and running! need some adjustment and a new clutch, slipping on 4th..
boost pressure 7-10 psi :)
trackjunkie21
« Reply #51 on: January 24, 2011, 09:13:52 AM »
Quote from: Bl0mgren;100806
We need videos now!:D
romkasponka
« Reply #52 on: January 25, 2011, 03:52:56 AM »
Go for m20 flywheel with 1mm clutch preload (measurement made from untouched by friction disc surface to pressure plate mounting surface). Will help you handle some 250hp for one season :P
E30 318is M42
E36 318is M44
Bl0mgren
« Reply #53 on: January 25, 2011, 09:45:03 AM »
Will change to M20b23 flywheel, M20 starter, M20 pressure plate and a 6-pad sintered clutch disc.
Also a electric fan is on the list :)
strypt
« Reply #54 on: January 25, 2011, 02:59:02 PM »
Skip the sintered clutch disc and buy a Sachs '618 pressure plate instead and use a standard 325 organic clutch disc. Will hold much better and also better driveability. Maybe a bit more pricey but you won't regret it in the long run.
That's the setup I use on my 318is turbo, works great.
romkasponka
« Reply #55 on: January 25, 2011, 05:41:55 PM »
Quote from: strypt;100859
Price is not nice at all :(
http://www.pure-pf.com
E30 318is M42
E36 318is M44
Bl0mgren
« Reply #56 on: January 26, 2011, 01:42:33 PM »
http://www.youtube.com/watch?v=-qOGlOTYx-4
need new FPR for more fuel and fix the dumpvalve, it's stuck :)
Bl0mgren
« Reply #57 on: January 29, 2011, 11:17:58 AM »
romkasponka
« Reply #58 on: January 30, 2011, 01:29:39 PM »
Quote from: Bl0mgren;100973
driving on ice! :D
http://www.youtube.com/watch?v=SBGQKju3z3o
Looks like on tarmac ;)
E30 318is M42
E36 318is M44
Bl0mgren
« Reply #59 on: January 30, 2011, 04:21:01 PM »
Quote from: romkasponka;101001
frozen lake ~ 45cm thickness :)
