DISCUSSION
Engine + Driveline
E36 Oil Pan on E30 M42
Topic: E36 Oil Pan on E30 M42 (Read 3708 times)
NitroRustlerDriver
October 02, 2010, 08:44:11 PM »
I'm trying to clarify what all it takes to put an E36 oil pan on an E30 M42. All I need to change is the oil pump pickup and the pan, correct? The E36 pan is once piece as well, right?
Thanks.
E30 and BMW stickers - Buy
here!
Andrew Bird
B318M42W
Sr. Member
October 02, 2010, 11:29:34 PM »
The E36 oil pan will not clear the crossmember supporting the engine. to fit an E36 M42 into an E30, you have to switch your E30 pans to the E36 engine.
M90 Blown M42 :cool:
NitroRustlerDriver
October 03, 2010, 01:52:19 PM »
The engine is going in my MG, not an e30.
The crossmember in the MG is far forward, so I will need the rear sump pan, but the engine I have is from an e30. I just need to know what all I need to switch to an e36 pan.
here!
Andrew Bird
wazzu70
Nasty Nick
Hero Member
-Receive: 18
October 04, 2010, 12:06:21 AM »
That should be pretty awesome in the MG!
I don't know for sure, but I think all you would need is the different pickup for the rear sump. If you go to
http://www.realoem.com
and look at the e36 M42 versus the e30 M42 you should be able to find all the parts you need with the correct part numbers.
-Nick
91 E30 M42 with VEMS
NitroRustlerDriver
October 04, 2010, 01:58:25 AM »
Yeah, I already looked and it seems to be all I need, just wanted to clarify. I've seen it talked about here before, but when I search "e36 oil pan" I get nothing.
here!
Andrew Bird
fabe
Reply #5 on:
October 04, 2010, 07:45:03 AM »
you dont' need anything other than the E36 oil pan, the oil pick-up line is built in.. probably just need a replacement rubber gasket...
DISCUSSION
Engine + Driveline
