Author Topic: Is this noise my timing chain/rails? (video)  (Read 3785 times)
Zoso
« on: September 15, 2006, 05:54:14 PM »
There is a new rattle in my engine and a new timing chain hasn't solved the problem.
Do you guys think this noise is a worn timing chain/guides/sprockets?
I made two copies of the same video - 1 in high quality and 1 in low quality.  You'll need Windows Media Player 9 or greater to play the video.  Please right click and save as.  My server is fragile and slow :)
http://zoso.no-ip.org/videos/318i-rattle-hi.wmv
http://zoso.no-ip.org/videos/318i-rattle-lo.wmv
« Last Edit: September 15, 2006, 06:00:11 PM by Zoso »
« Reply #1 on: September 15, 2006, 06:59:48 PM »
Wow.... it is fragile and slow....  :)
Hang on...
Jimmy
« Reply #3 on: September 15, 2006, 07:33:33 PM »
Quote from: Jimmy
My money is on #3 http://www.realoem.com/bmw/showparts.do?model=AF93&mospid=47305&btnr=64_0552&hg=64&fg=50
I don't think I even have #3...
First thing I would do is pull the belts off and see what that does to the noise. Barring that, I would bet that there is something loose inside the timing case.
Zoso
« Reply #4 on: September 15, 2006, 07:53:11 PM »
Quote from: ak96ss
Did you get the video?  I was downloading a .torrent file... that always fouls up my router and makes everything slow.  The torrent is done now.
Good idea, guys, about pulling the belts off.  I'll give that a try before ripping my engine apart.  I, too, believe that something is amiss inside the timing case.
Hope it's cheap.
« Reply #5 on: September 15, 2006, 10:28:51 PM »
Quote from: Zoso
Who did the work?  Do they know what to look for in the guides, sprockets, etc. or did they just stick a new chain in? What did taking off the belts do?
Hope it's cheap.
Zoso
« Reply #6 on: September 15, 2006, 10:51:44 PM »
Quote from: D. Clay
Hope it's cheap.
Crap - typo.  I replaced the timing chain TENSIONER.  The timing case has never been opened to my knowledge.
