I thought i would start a biuld thread for my itb set up.
im using 50mm itbs from an e36 m3. all iv done is pull the manifold off to trail fit the itbs and make a 'to do' list. i was thinking i will block of the heater hoses so i only have one pipe going from the block to the bottom of the radiator.
i need the modify the fuel rail because the return pipes hits on part of the tb
they are the main things, other little things like grinding the corners off the itbs should be pretty easy
so there is a little bit of work to do. any surguession/comments would be greatly apreciated.
