DISCUSSION
General Topics
compression results....im confused
Topic: compression results....im confused (Read 2630 times)
91318radmobile
August 05, 2010, 04:05:15 PM »
every cylinder was really low but they were all the same....130
what could this indicate?
head gasket?
any input would be appreciated. thank you i did this because its overheating and the cooling system if all new except for the radiator and fan clutch, which i know works just fine
Last Edit: August 05, 2010, 04:36:19 PM by 91318radmobile
jscribble
Sr. Member
August 05, 2010, 08:25:37 PM »
Leakdown test on all cylinders would tell you if your rings are smoked. 130 is only a few lbs under spec iirc. Still, low compression = sad motor.
Betty - Sold
Sabine - 2004 325xi
91318radmobile
August 06, 2010, 12:31:26 AM »
thanks thats the next sep
KenC
Sr. Member
August 06, 2010, 08:56:30 AM »
I'm surprised it runs at 130. You should be up around 200.
91318radmobile
August 06, 2010, 09:19:47 AM »
its running great, im pretty sure i did it right, warmed it up and opened the throttle all the way
91318radmobile
Reply #5 on:
August 10, 2010, 08:47:46 AM »
head was warped, got it machined, but do i need to do the timing cover too?
DISCUSSION
General Topics
