never posted here before, but i need to talk about my frustration:D
I have build turbo engine m42
td-05 turbo(lance evolution)
custom header
forge intercooler
engine block honed 85 mm
mitsubischi evo pistons 85mm
MLS head gasket
head flowed
stock cams, overlap turned away
ARP head bolts
ARP conrod bolts
M50b25 135mm conrods
New bearings
new gaskets
crankshaft balanced
flywheel lightened and balanced
Engine was running fine until i had wrong made pistons, now i have evo 9 pistons. so 1 have had the head off 1 time.
yesterday on dyno i had 270 HP on 1 bar boost, pretty good, but on 2nd run the pressure came out of carter ventilation.
the car still standing there i dont know what to do. Pull the fuckin head and pistons AGAIN:mad:
one time during break in, i had broken coolant hose, so engine was hot. After the fix temparature was fine, ONLY when i pulled the oil cap there was already a lot of pressure. But didnt rise when on throttle!!
during Dyno there was no detonation or what so ever. Ignition advance was very weak, not tuned yet!
What will be wrong? only piston rings? or pistons? Cilinders
I dont want to trow in a lot of money. Next year i go to college again.
i am a little frustrated so if i am not very clear i'm sorry. Give me your opinions, i need them:o
